Question about Hotpoint Dryers
Dryer not getting hot hotpoint dryer model#dlb2650bslwh
  • Hotpoint Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 28, 2011
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
Our electric hotpoint dryer stopped spining & got hot & it smelled hot now we can't even get it to turn on
Let's start with the easy stuff.
Check the belt
Thermal fuses
door switch
Do you know where they are?
Dec 12, 2012 | Hotpoint Dryers
Hotpoint Dryer has burning smell, checked vent--ok,checked screen just inside--ok. Drum turns. Four screws on back with depression space are extremely hot.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 27, 2011 | Hotpoint TDC32 Electric Dryer
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Hotpoint gas dryer will not get hot
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 02, 2010 | Hotpoint NVL333GY Gas Dryer
Model nbxr453evoww takes too long to get hot
Sounds like your heating element is on its way out. If you understand one it is just wires that coil around a shroud,over time it only has to get weak or break in one spot.I suggest replacing it.
Feb 16, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element ..ge/hotpoint elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
110 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
