Connect Slick 4gb mp414-4 to computer to charge it up and it says "open the switch charge", what does that mean? What switch?
Slick MP3 player
Hello, if you don't have any message from the mp3 either the pc , is because the usb cable you are using only allow charge and no data transfer, try to change cable.
Thanks
Nov 22, 2013 | Audio Players & Recorders
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
Ok i have a Slick Touch music and Video Player MP550-4 4GB and im trying to download music from my music to mp3 but it doesnt go on the music file in the mp3 it goes on the browser file on my mp3 and i...
when you connect it to the computer, go to "my computer" and look for it as a 'device' like the harddrive on your computer would appear (Local Disc (C:) ) and open it like a regular folder - you may have to right click and select "explore" - this should show you the available files on the device and allow you to select the option of putting your music in the music folder itself.
Owners Manual
Jan 09, 2011 | Audio Players & Recorders
My slick mp3 play wont turn on but when plugged into the computer it says ready
The manual for a 4Gb slicK player states: turn the power switch to "on" and hold down the play/pause button until the unit powers up. You can also power down the unit in the same way, (while leaving the switch in the "on" position).
Sep 02, 2010 | Bell Technology Techsolo Slick Stick MP3...
Help with a slick mp3
Connect your MP3 Pod to your computer via a USB Cable and once it gets recognized then go to the new drive detected in your computer and right click on it and select the "Format" option and select "Quick Format" and try to format.. If it says that "Format could not be completed" then try changing the filesystem and again formatting, If problem persists then it means that your hard disk in the player is corrupted..
May 29, 2009 | Audiophase Audio Players & Recorders
249 people viewed this question
 Grubhead
Grubhead
