Question about Cycling
I want to know how to adjust the front & rear derailleur because when I change gears while riding sometimes I have to play with the shift lever to get it to fall into gear. Where can I find an adjustment manual
    Brigadier General:
  • 8,546 Answers
Chain intermittently slips in all gears. Is there an adjustment
Mark:
First of all, make sure that you are not over or under shifting. The chain has to be positioned exactly over the gear that you are trying to use. If you hear derailleur or chain noise The derailleur is not "in gear" and you have to adjust your shifter to eliminate noise. The derailleur must be adjusted so that the chain is parallel to the gear cluster in each gear. If the chain is twisted at all, it will skip gears. Check your rear derailleur to ensure it is pointing the chain directly at the front gear cluster. Check the front derailleur to see that it is pointing the chain directly at the rear derailleur. While you are at it... clean the derailleurs with alcohol and lube them with a light weight oil. Check the derailleur stops (small screws next to the cable clamp on the derailleur). Have the bikes rear tire off of the ground and pedal the bike with one hand while shifting with the other hand and you can see what the derailleur is doing. adjust the stops so that you can not shift the chain off of the gear cluster in high or low gear. You may have to adjust the cable length at the derailleur cable clamp, and at the adjusters on the shifter to get the exact adjustment that you want. It will take some time to properly adjust your derailleurs, but it is worth it when you can ride without your derailleurs acting up.
Jun 15, 2015 | Cycling
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
How do i adjust the tension on the cables which control the triple chainring [ shimano 515 ]gearing and the rear gearing? presumably there will be other adjustements to make after this is done.
The tension on a derailleur cable is determined by a spring in the derailleur itself, and is generally not adjustable. The available adjustments on the derailleur control the limits to it's travel (and in the case of the rear deraileur, the chain tension). The shift levers that you operate to change gears generally have an adjustable resistance (to keep them from sliding into another position), but this has zero effect on the tension on the cables. If you have indexing shifters there are additional adjustments. If your cables are going slack it might seem that the spring in the derailleur is too weak, but this is a lubrication issue, or you may need to replace your cables. There is a good article on derailleur adjustments at - http://www.parktool.com/repair/readhowto.asp?id=64 Good luck
Aug 12, 2010 | Cycling
Deraileur adjustment/tuning
Yeah you will run into that at some bike shops. When they see older components like that, they often refuse to adjust them for fear of breakage and liability. Try a different bike shop if you can, or if you are confident in your mechanical abilities, try it yourself, instructions here:
http://www.ehow.com/how_6086607_adjust-shimano-rear-derailleur.html
Good luck.
Mar 27, 2010 | Shimano Xtr Mountain Bike Dual Control...
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
How do I operate 10 speed road bike?Schwinn La Tour How do I change gears
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Oct 02, 2009 | Cycling
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 | Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Sep 02, 2009 | Cycling
Wont change gears 12or3
There should be one or two limiting screws for the front derailleur that you can use to adjust how far out/in the derailleur moves to shift the chain over. You can ask a friend to lift the back end of the bike off the ground while you do the adjusting of these screws and then try shifting the gear while moving the peddles with your other hand.
Aug 21, 2009 | Huffy Womens Mountain Bike - Passion...
Shimano 105. Front derailleur won't shift down
It sounds like you could have two different problems. Your derailleur has become contaminated or your shifter may need to be lubed. Either way, the likely solution is the same. The best solution to get the derailleur operating again is to spray it with GT-85 or PB blaster and manually move in back and furth until it is working again. The same goes for the 105 shifter, spray GT-85 inside the shifter by compressing the brake lever and spraying towards the head of the shift cable. This will solve a non-functioning shifter many times.
The only other problem that fits is the limit screws could be wrong or the deraileur is in the wrong position. This would not be the case unless someone adjusted your derailleur before the ride you started have that problem. Or if the derailleur has moved. Both of which require the derailleur to be fully readjusted.
Hope this helps. Thank you
Jul 15, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
42 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
