Need a user guide or manual for the Bostitch B300HDS Heavy Duty Stapler
Suzman
  • 642 Answers
SOURCE: I have a Swingline High
At the rear of the stapler is latched retainer(looks triangular when viewed from the side). Push it forward (toward th other end of the stapler) and lift up and back. This will release the "tray" that holds the staples.70a3245.jpg
Posted on Oct 31, 2010
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
SOURCE: looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Posted on Jun 04, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bostitch stapler T40S2 has air leak at trigger. I
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
SOURCE: B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
Posted on Feb 02, 2010
The staples won't go all the way down on my Bostitch Heavy Duty Manual stapler. Why?
How old is it and how much has your stapler been used?
The hammer could have been bent, worn out, or broke a piece and is too short to push the staple all the way.
The only way to check it is to take it apart and see how the hammer looks.
Dec 03, 2016 | Staples Tools & Hardware - Others
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
My Bostitch 20Suite office stapler won't staple and isn't jammed
Hello, Go to this website for instruction manual download. It also will have a number u can call for tech support to talk to a person, if further help is needed. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Jun 04, 2014 | Stanley Bostitch 20SUITEBLK Heavy Duty...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I have a model B310HDS heavy duty stapler and the spring mechanism broke on the end. Where can I find the replacement part? Thanks
what you are looking for what they call a pusher assembly.
Bostitch company uses Amex(SP?) for their replacement parts.
The phone number is 800-343-9329
Jul 21, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
Bostitch 02210 stables once, then jams
Biggest olptrit on our office is people putting the wrong staples in it... Check to make sure the ones that are in it are on the approved list.
Peace,
Mar 03, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Oct 06, 2008 | Stanley Heavy Duty Stapler, Cast Aluminum...
591 people viewed this question
k24674
jasbo
jasbo
