Question about Sony KV-32FV27 32" TV
When I turn my tv on, within a few mins the picture starts to turn red untill it is solid red and you cant see anything but red
  • Sony Master
  • 6,694 Answers
Your tv has problem with the base board. you can see the base board on the picture tube neck. To see the base board you have to open your tv. The problem is dry soldering of component in the base board. To rectify the same you need soldering iron. Just check the base board carefully for any dry soldering of component leads. (dry soldering means loose contact or bad contact of component lead in the soldering side of the base board can happen after years of use.). Just find out the point which is dry. resolder the point using the soldering iron. that's all. then test the tv it will be ok.
If you can't find out the exact location just resolder all the points in the base board. it will take some time to do it . just take your on time and carefully do the same. If you nee any more assistance feel free to contact me through fixya.
Below i have added a picture , how the dry soldering looks like. The points inside the yellow circle
ok
Posted on Mar 28, 2011
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Sony Bravia KDL-55EX500 flashing green and yellow light, an won't turn on. Any suggestions?
you guys are going to love me. lol. i figured it out at least for mine. $ )
1.start by unplugging the tv and everything plugged into it(make sure the only thing plugged into the tv is the power cord).
2. next plug in the usb flash drive with the update or a compatible version of the firmware.
3. now while holding down the up arrow button on the tv remote, plug in the tv and keep holding the up arrow while pressing and holding the power button on the side on the tv until you see the light on the tv go from solid green to solid red and yellow flashing lights. once you see this just sit back and wait a few min for it to force the update and it should turn on when its done.
let me know if this works for you as well or if you need any clarification. also know that step three is a pain to do alone and must be all done within a short period of time preferably at the same time.
I’m happy to help further over the phone at https://www.6ya.com/expert/ian_82ea3666497c1024
Oct 16, 2011 | Sony Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
Toshiba 60 in projection tv picture goes out. the screen is black. unplugged until red light goes out, then restarted and picture comes back fine. until it happens again. 3 times in about 15 min. it...
the unit is developing whats called a "cold solder joint"...have it resoldered before it becomes a burnt out section of printed circuit board if it starts to arc...
Jul 25, 2009 | Televison & Video
Toshiba TN 50V71.
the start up or standby power is in need of troubleshooting. I would start by checking the regulator and horizontal output transistors.
Mar 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sylvania 6842PF M screen turning dark red
This sounds like the color processor IC is not working properly. If this is the case you will have to have this checked by a qualified technician.
Sep 21, 2007 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Sony KV-32FV27 32" TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
