Question about Philips Philishave HQ7782 Electric Shaver
Batteries don't charge anymore.where do I find anew battery pack, and how do I install it?
  • Philips Master
  • 1,624 Answers
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Mar 30, 2011
Canon a4000 saying change the battery pack
Try to charge the batterie. If you already did charge, it could be the battery does not have enough capacity anymore and you should buy another one. Please if you have not used the camera for a long time, try charging the battery several times, till the charger says it is full and then use the battery. Sometimes you could revive the battery this way. If not buy a new one.
Dec 30, 2013 | Cameras
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and...
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
HOW DO I CHARGE A MERITS DMA SCOOTER?
With the battery charger lol I don't know if your scooter has the battery pack or not but if it does there should be a charger port located on the battery pack just plug the charger into the port and let it charge overnight. If it doesn't have the battery pack then there should be a port located on the tiller usually under the throttle levers Hope this helps
May 09, 2011 | Health & Beauty
Battery has stoped working and has swelled in
This is because the life of battery is finished.This occurs due to prolonged charging.
Please replace the battery.DONOT charge anymore there may cause explosion of the battery.
Thanx
Jul 27, 2010 | GPX PDL805 Portable DVD Player
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Toshiba Laptop will not stay on
Yes, you need to get a new battery pack since it does not charge anymore.
Jul 29, 2009 | Computers & Internet
Charging problem
The same problem I have.
Defective battery.
Mar 16, 2008 | Olympus Camedia Stylus 300 Digital Camera
Philips Philishave HQ7782 Electric Shaver Logo
148 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
