Question about Roper RAS8445KQ Top Load Washer
Washing machine filter for roper top loader
I cannot find the filter in the tub. Is there one. It smells really bad in there
  • 481 Answers
It has a self cleaning filter mounted under the tub. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Posted on Aug 04, 2008
  • Nixon VanJustice
    Nixon VanJustice May 14, 2015
    How do I clean out the self-cleaning filter under the tub?
I have a roper washer that is level but when spinning machine jumps around not over loaded but not as bad with only one or two items
top loader
the problem indicates that the air dampeners on the ends of the support rods for the tub have failed
with them broken any small out of balance is escalated to the machine walking around the floor
Dec 02, 2017 | Roper Washing Machines
Burnt rubber smell during spin cycle
Assuming it's a top loader, the coupling between the motor and the tub is failing. If this is an older machine, the cost of replacement may not be within reason. The cabinet has to be removed and additional disassembly is required to replace the coupling
May 15, 2013 | Roper RTW4300SQ Top Load Washer
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
It makes my clothes smell really bad
I am not familar with this machine...but
it probably has a lint filter on the washer somewher inside the tub. Probably close to the front. also these front loaders have a big rubber seal, check and make sure nothing has fallen in between them. They make a specific product for cleaning these machines, sell it on same isle as detergent.
Jul 19, 2009 | Samsung WF337AA Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RAS8445KQ Top Load Washer Logo
184 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
