Question about Poulan 25CC Gas BlowerVac
Poulan pro sm400 will not start new plug new gas clean filter no fire to plug what next
  • 3 Answers
I HAVE DE SAME PROBLEM, TODAY I´M GOING TO CHECK DE CIRCLE BAHIND THE FAN PROBALY ITS MOVED (ROTOR)
Posted on Apr 07, 2011
Carburator
You still have a fuel filter, fuel lines and maybe a primer bulb to check too. Make sure you're getting fire to the plug and fuel.
Aug 29, 2014 | Poulan Pro Pp125 17-inch 25cc 2-cycle...
Won't start
Starting problems with 2-cycle engines are usually traced to fuel line/filter clogging due to jelling of the fuel mixture while the engine is idle. Best fix is fuel mix pretreatment with some kind of gas saver in the gas can. Marine grade additives are the best, such as 2+4 gas treatment. Now your stuck with pulling the fuel lines and blowing them clean. If the carb has a primer bulb, you can sometimes force the fuel through, but a complete cleaning is in order. Pulling the plug and putting a few drops of fuel mix directly into the cylinder head, (or in the air intake), can sometimes get the motor to fire. This proofs the problem as being fuel starvation.
Jun 01, 2010 | Poulan Pro Gas BlowerVacuum ()
Poulan pro lawn mower starts & dies
unless this mower is older then i am, it has no points or condenser. It has only a magnito. Sounds more like a plugged up carberator.
Apr 30, 2010 | Garden
Poulan Pro won't start
1. You may have old gas in the tank.
2. Fuel mixture may not be quite right. Pour out and put new in it. Otherwise you may need to clean the carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Nov 29, 2009 | Poulan Featherlite Gas Blower, with Low...
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
My poulanpro gas blower SM400 will nt start, i put in a new spark plug
if it's been setting up for a while the carb and tank may need cleaning and sometimes the little fuel pick up line will crack, alowing air to be picked up .you might try putting a very small amount of fuel mixture into the carb or into the cylinder then replacing the spark plug to see if it is indeed a fuel problem.
Oct 23, 2009 | Poulan Garden
Poulan pro lamn tractor will not start
Carb is most likely clogged from when the gas you had in it before gummed up. Take some carb cleaner and clean the heck out of the carb and everything will work just fine after that. I also recommend letting the carb cleaner sit for about 30 minutes before trying to start the machine
Jun 03, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 25CC Gas BlowerVac Logo
285 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
