Question about Carrier Heating & Cooling
Don't know the model # to an old commercial hvac system but we know part # HK35AA009, sequence circuit board timer, should be replaced. Need to find manual/diagram regarding the timer - can you assist me?
  • 148 Answers
Read the compressor model #
Posted on Apr 25, 2014
5 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 80 Answers
SOURCE: I have just replaced my HVAC Control board &
Once you have installed the jumper, you will need to kill power to the furnace for about a minute to reset the board. Make sure the the jumper is making good contact. Sometimes they appear to be plugged in but still are not making contact.
Posted on Oct 04, 2009
atocrxr
  • 135 Answers
SOURCE: Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Posted on Apr 04, 2010
  • 588 Answers
SOURCE: Need Coleman CSC II Model 7341D901 Manual
You might try ColemanAC.com
They might be able to help you or lead you to somebody that can help.
Posted on Apr 08, 2010
I have an Infiniti G 35 2003 and I cannot adjust the temperature settings or airflow nor does the audio equipment work
Common issue with the 2003 Model G35. The culprit is the radio/HVAC circuit board. Unfortunately, since the OEM radio and HVAC system is integrated, it means replacing the entire circuit board which can be pricey. Google "Infiniti ITB03-007" for more information.
Oct 09, 2015 | Infiniti Cars & Trucks
Air blowing cool on passenger side warm on driver side how to fix this
sounds like you have a temp door motor problem on the drivers side. the motors seize/stick and have to be replaced.
Aug 09, 2015 | 2005 Buick LeSabre
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Need circuit board to control temp. It is jrsrr-10b
l is no longer available, the only thing you can do is re-wire the control section to use a simple thermostat and timer to control the condenser and leave the old controls for a thermometer only.
Oct 21, 2013 | Coldtech J4SRR-40B Commercial Refrigerator
Model #417.41142000 Circuit board has been replaced to correct drum not spinning. Now timer won't advance.
are you Shure that the cable has not come off the spin pause button or from another part of the cable loom its worth checking eric
Dec 26, 2017 | Kenmore Washing Machines
For a church HVAC ysem, we need detailed instructions on programming a Grasslin 2 channel, 7 day, 24 hour digital clock. Ned Spencer Programming the Grasslin is a tough job. Together with an...
Open following link to identify timer module:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
Link for FMD 2-channel Intermatic timer
http://waterheatertimer.org/pdf/fmd-50-setpoint-programming-guide.pdf
1-channel FMD Intermatic timer
http://waterheatertimer.org/pdf/GM40AVE-digital-timer-programming.pdf
FMD timers are complex to program, and if timer does not program correctly, then check voltage and polarity of circuit. These timers typically have 1 year limited warranty and can be affected by power surge.
If you have 2-channel timer, then each contact on relay will turn on-and-off at different schedules.
Make sure you don't wire both legs of a 240Volt circuit to to different relays, or the circuit will not turn on-off as expected. To control 240V, just turn off one leg using one of the relays.
If your exact timer does not show, add a comment and describe everything about the timer buttons and appearance, and I will search my files for possible manual.
Grasslin timers were made by GE for many years, and now Intermatic owns the product line.
Jul 11, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
I have a LX80 Commercial pool and Spa Control System made by Pentair. I notice this morning that the jet spa motor was running all the time. Which is not right because the control panel is set for 15 min....
If you are positive that the two hot lines onto the motor relay are in the correct postition, then it is the control wires not giving power to the relay to close the circuit. Make sure the signal wires are connected to the contrl board. then, check to see if the timer is still working. its always possible that the control board has failed under the surge conditions. If signal wiring is in place and relay still wont close the circuit, disconnect the relay signal wires, set the timer to come on, and after it tries to activate that relay, measure for 24 volts at the relay signal wire terminals. If no voltage is found, bad timer, or bad board.
http://www.pentairpool.com/pdfs/LX80IG.pdf
above link has wiring diagram included incase needed
Jun 08, 2011 | Pentair LX802L Commercial Pool/Spa Control...
Need to know the value of a resistor
Tim, I am a commercial hvac, refrigeration, and commercial kitchen equipment mechanic. I have rebuilt many of those units. While the notion that all it might be is a 20 cent resister is noble, you are forgetting that this particular circuit has been in service in airborn oil, dust, moisture, spices AND MORE THAT attack ELECTRICAL/ELECTRONIC/COMPUTERIZED equipment.
After many years of repairing vrs replacing, the failure rate was so high in other components and circuits that I realized it just wasn't worth it. Its NOT JUST THE COST OF SERVICE AND PARTS, but also THE DOWNTIME AND LOST SALES you need to take into consideration as well.
Take it from a professional, REPLACE THE BOARD!!!
Nov 11, 2008 | Frymaster Dean MJH50-SD Deep Fryer
Evaporator coils iceing over; warminhg on frig side of model 106....
As I said; the fan and compressor run fine but I cannot find the defrost timer. Is it integrated into the control board.
Thanks
Jul 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
