Question about RC Toys
Helicopter (Easy Copter V6) will not quite leave the ground now. New battery doesnt help. Rose OK when new. Live 1000 ft AMSL.
    Top Expert:
  • RC Master
  • 81,400 Answers
Hello
If the battery is new and fully charged and since the rotors are a fixed pitch the only thing that can cause this is that the electric drive motor for the rotor blades is defective.
Posted on Mar 28, 2011
  • Marvin
    Marvin Mar 28, 2011
    If are going to try and repair this it may be helpful to know that the Easy Copter V6 uses the same parts as the Walkera 5g4 RC Copter.
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Can't get helicopter to respond to remote
try buying new batts for the control
Jan 26, 2013 | Toys
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Dec 25, 2010 | Toys
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Toys Logo
189 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
