Question about Moen Plumbing
How do I remove the cartridge in a Moen 87439 kitchen faucet to install new O rings? Thank you Wayne
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
    did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
    Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
    I cant stop my Moen single lever kitchen faucet from leaking. how can I fix it?
    1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
    The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
    THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
    Reassemble and enjoy.
    2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
    Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
    The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
    www.plumbingpartsdepot.com/moen7300.gif
    http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
    Good Luck.
    Sep 08, 2009 | Moen 87530 Touch Control Single Handle...
    Dripping faucet
    Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
    Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    166 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
