Question about Asko 1385 Dishwasher
Replaced new timer, wax motor, switch fan dry switch, thermostat switch due to recall. Replaced circ pump due to beads from rack falling into the dishwasher and grinding the pump. After all this, the timer does not advance. Saw on another post that if the sensor inide the tube to the level switch is damaged the entire bottom well will need to be replaced. Would a damaged sensor near the well allow the dishwasher to fill with water, but not advance the timer? If so, I know it's not a pleasant job, what steps would you take to replace the well?
  • 2 more comments
  • cdracos Mar 28, 2011
    This would be acceptable if this were not an Asko. The mechanisms are different, particularly near the well.
  • cdracos Mar 29, 2011
    Thank you for posting. This is on how to repair a level switch. I was searching for guidance on installing an asko well.
  • cdracos Aug 26, 2011
    MacMarcus
    You responded to my post some time back. I'm just returning to the Internet to finish the job that I started in Sept 2010. My dishwasher does not work after putting in may new parts. Some suggested by you. My dishwasher has a a new sensor, new timer, wax motor, switch fan dry switch, and new pump. The dishwasher will fill with water to wash, but does not advance through the cycle. i ordered a new thermostat to see if that will help....
    Will you please respond to my post?
  • cdracos Aug 27, 2011
    Sorry to offend you Macmarkus. That is not my intent. I'm very frustrated.
    The most expensive part "suggested for replacement" was at this post.http://www.fixya.com/support/t6557583-as...
    The wax motor, switch were a recall by asko. The timer was recommended by another expert.
    At this point, I paid for a solution and the machine does not advance.
    What do you suggest the next step to be?
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
Before I make any assumptions, I'll try and clarify what it is you want to do...or better yet, why you want to change out the sump well. Is it busted ?
**Pardon me for this if much of this has been covered, but I do not have access to any previous post or dialog for some reason.**
When you mentioned (in your words), "Would a damaged sensor near the well allow the dishwasher to fill with water, but not advance the timer?" yes it could...but more likely it would cause the drain pump to run continuously or the unit to overfill every time, or not fill at all.
Here's where I'd focus your attention. The pressure switch is located on the right hand side (from the front) as shown here...Large arrow indicates the switch, the small is the hose which goes to the back of the sump-well.
Also something of interest you mentioned was the thermostat you replaced. Which one ? Most of the Asko have a minimum of two thermostat's and usually three as shown by #16, 17 & 18 in this parts illustration.
These are usually in this order...furthest to the back is 30-70C, center is the hi-limit @ 88C and then the closest to the front is rated @ 53-64C.
According to my info from Asko ( I used to be a servicer for Asko from 1997-2005 ) The issue in the past has been this, in regards to timers not advancing...
it has happened that the timer has stopped in the drying sequence. The reason for this is, that the distance between the heater and the bottom over the overheating protection is too small. Then the overheating protection, 88° C, breaks the heating before the drying temperature reaches 70° C and thereby prevents the timer to step forward.
Try this: Adjust the distance between the heater and the bottom to 4 mm.
Let me know if anything here has already been covered and therefor redundant...I hope note. I will watch for your reply.
Regards,
Macmarkus :)
Posted on Mar 29, 2011
  • Mark MacDonald
    Mark MacDonald Aug 26, 2011
    I'm just replying to a post you added to your thread on the Asko dishwasher.
    Of course I will help in any manner I can, but I have to take exception to the statment in your post, "My dishwasher does not work after putting in may new parts. Some suggested by you. My dishwasher has a a new sensor, new timer, wax motor, switch fan dry switch, and new pump."
    I replied on only one occasion (feel free to check your thread, I am Macmarkus as you said) to your initial post and at no time did I suggest replacing anything. You obviously have confused me for another expert. Changing parts as a solution is rarley the way I go about solving problems such as yours..."timer not advancing".
    Certainly I would suggest methods of eliminating possible causes and offer solutions, (as I indeed did) but not replacing such parts as you've mentioned.
    Regards,
    Macmarkus :)
  • 4,323 Answers
Hi
Please check this video to replace the well:
Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 28, 2011
  • Daniel Scott
    Daniel Scott Mar 29, 2011
    Did you read remaining part of the answer....Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps...please post back for further assistance.Daniel
    Brigadier General:
  • 3,513 Answers
Hi
The wiring that comes from the bottom of the tank and rises up the door is prone to burning. Before doing the following remove power from your dishwasher. By removing the kick plate at the front and inspecting the bundle of wires you may note that some of the wires are lumpy or burned. These wires need to be repaired. Failing that there is a cycling thermostat mounted to the bottom of the tank above the water valve. These cycling thermoses will prevent the timer from advancing there should be a wiring diagram inside of the door that will help your efforts.
Please check the links bellow for more details:-
http://www.partselect.com/dishwasher+test-timer+repair.htm
http://books.google.com/books?id=7N48z4urzogC&pg=PA129&lpg=PA129&dq=how+do+you+replace+dishwasher+timer+dial&source=web&ots=_ivKZBcuRx&sig=twotriGvxrWQ4q5qCTV-_YDMtGM#v=onepage&q=how%20do%20you%20replace%20dishwasher%20timer%20dial&f=false
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
Detergent dispenser problem
Is it new? Even if it was or wasn't, I strongly feel that you probably didn't set something properly. Read the manual it came with, particularly the troubleshooting section. Not a big problem. Let me know how it goes. :)
Jun 29, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Replacing wax motor
Not very difficult actually. Strip of the screws around the inside of front door, and the two on top of the panel. Twist of the fan cover, and then the wax is attached with a Torx 10.
Sep 02, 2013 | Asko Dishwashers
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
My 2000 Jeep Grand Cherokee overheats in idle and when the A/C is being used, have replaced thermostat, relay switch, radiator and water pump what could be the problem.
Sounds like your radiator fan is not working.
Have your replaced the fan or fan motor?
Fan motor will cost $100 /diy
Also, check for recall on this fan and motor through Jeep
Jul 09, 2011 | Jeep Grand Cherokee Cars & Trucks
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
Dispenser does not work
Hello there:
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
Jan 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
AEG 7080 will not go farther than the main wash.
May be but have you checked to see what is in the pump that is restricting the pump out of all the water. This could be the main problem causing the heartache. Check the pump to make sure no pieces of debris is in it.
Feb 04, 2010 | AEG Dishwashers
When i choose normal wash and the cycle has been complete I open up the dishwasher and at that time the detergent pocket opens up and drips out the detergent. My glasses are all chalky and unclean
When the detergent cup doesn't open, check these:
Timer
Jul 16, 2009 | Dishwashers
Not using salt
Timer
Jul 06, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Asko 1385 Dishwasher Logo
219 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
