Question about Blenders
LEAKS OUT AT THE BASE WHERE THE BLADE IS SCREWED
  • 41 Answers
Most Blenders have a o ring seal where the blade goes.to keep it from leaking see if that is missing
Posted on Mar 28, 2011
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
My Jack Lalannen health master leaks. Don"t know how to fix it.
You did not specify where the leak is coming from, so I can only guess and my guess is the base. Assemble gasket first, then blade plate and then base retainer. You can tighten the base tighter while the unit is on the motor base. the motor base will let you get it slightly tighter.
Dec 12, 2010 | Jack Lalanne Health Master 100 Blender...
The bobby flay blender leaks out the bottom where the blade is screwed in
Take it apart and pit the gasket on the other side of the cutter assembly.
Oct 04, 2009 | KitchenAid KSB3 Classic Work Top Blender
Leaking blender
It could be the gasket, could definitely be that crack in the collar, and even possibly the blade assembly - here is the official website to get all of those parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Mar 31, 2009 | Back to Basics 600 Smoothie Elite Work Top...
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Aug 27, 2007 | Tefal MagiClean Work Top Blender
Blenders Logo
108 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
