Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Model# 363.5022200 side by side refrigerator
I think I have a freon leak or low charge of freon( Because ice ball on the back) refrigerator, Can this be fixed and recharged and how much would it cost
fridgetech
  • 473 Answers
SOURCE: refrigerator admiral
Frost on the low side line means the system is overcharged (too much freon).  Look on the tag insided the fridge and it will tell you how much freon it holds.  Usually 4.25-5.50 ounces on average.  The loud noise sounds like you have air in the system.  I would evacuate, from the high side while running, and let it run empty for 5-10 minutes.  Then while running put the valve core back in the high side.  Then unplug the fridge and charge with proper amount of freon thru the high side.  Wait about 5-10 minutes and plug back in.  Normal low side pressure should be 0-3 psi.  This is a good indicator of the proper amount of freon in a good working system.
Posted on Oct 14, 2007
  • 262 Answers
SOURCE: my refrigerator/freezer isnt getting cold enough
The problem usually isnt in the freon it usually is in the defrost system located in the freezer.I guess you have got this fixed by now and Im sorry for taking so long to get back to you but I havent used the computer in about four months because of family emerg. if you have any more problems let me know.
Posted on Nov 14, 2008
  • 56 Answers
SOURCE: condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
Posted on Dec 06, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
aasc
  • 1606 Answers
SOURCE: need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Posted on Aug 20, 2009
How to charge freoon in sce275 ice maker
Why would you wont to change the freon? It would cost more to convert one freon over to another than you could buy another ice maker for. You cant just change freon over from one type to another. You would have to change the compressor, the TXV, all dryers, Make sure you have removed all the oil from the system that is trapped. Now if it is low and you are wanting to charge it back up then you need to find the leak and repair it first.Refrigerants do not deplete them selves so if it is low than you either have a leek or if you keep putting gauges on it then you loose some charge every time you do this. So if you have no experience with a refrigerant system i would call a service company.
Jun 08, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
How do mi check the freon
Refrigerators don't need freon added to them unless there is a leak and until you find and repair the leak you have not fixed the problem.
A lot of people think when their refrigerator is not cooling that they need to add freon. This is not normally the case 99% of the time. You are a lot more likely to have a defrost problem or a fan problem if your refrigerator is not cooling.
If you actually do need freon, call a reputable professional. There are a lot of guys out there that will just add freon because you told them it needed it, charge the heck out of you and then leave. Be careful about telling some jack leg that you need freon.
Jun 27, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My sub-zero refrigorator is icing up on the first
Hello
There could be some other reasons for the ice.
1 bad or cracked door seal,have a look at the door seals.
2 Defrost timer may need to be set longer.
3 T sat set to low or not working properly.
Unit may be low on freon also,causing a lower pressure which would cause a lower tempreture,this occurs with a small leak or a pin hole leak.Once enough freon leaks out it will warm up and no longer work.
You can have a leak check done by a service person.
May 13, 2010 | Sub-Zero 661/F Side by Side Refrigerator
Either side getting cold
Sorry - maybe I did not exactly understand . Anyway the cooling coil is inside the rear of the freezer and cold air for the fridge is blown from that area for cooling. You need to remove the rear freezer cover panel to check the coils for an ice buildup which stops the air flow and cooling.
If you see no ice then you may well be low on freon and most certainly have a leak. Removing the back will give you access to check those coils for a leak also.
To check freon pressures you need to buy a Bullet tap or two which clamp on the high and low side of the compressor and pierce the pipe like a ice maker water tap except the Bullet tap has aconnection for freon test and refilling hose
May 07, 2009 | Refrigerators
Condensor running, some cool air on both sides, not cool enough
There are 2 things I an think of right off. the most likely is a defrost problem. Look at the back wall of you freezer compartment and look for snowy ice build up if so most likely culprit would be defrost termination switch. the switch is inexpensive and easy to replace. you will need to order it by your model and serial number.
the next not as likely problem would be a low freon charge this problem would require a good service company to repair for you.
Good luck peyton
Jan 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator
you will initially have a rotten egg kind of smell aroundthe refrigerator.
Dec 14, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
Refrigerator admiral
Oct 14, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
