Question about Amcor 14000 Portable Air Conditioner
Blue dial flashing, drain doesn't drain, yet water is leaking from the bottom somewere.
    Brigadier General:
  • 4,736 Answers
The drain hole may be clogged and not allowing the unit to drain as it should. Check the drain hole for clogs and if necessary, run an 18" long plastic ZIP Tie (or something similar. No wire coat hangers, though), that will fit inside the drain hole, as far as you carefully can. Slowly remove it and be prepared for water to follow,
Hope this helps you solve the problem.
Posted on Mar 28, 2011
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Water runs out at the bottom of the front cover of the machine and doesn't spin properly?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jan 17, 2013 | Washing Machines
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Water leakage from washing machine
if water leaking only when draining it seems you have a leak somewere on the pump or conecting pipework the only way you can tell is by checking it wilst it is draining then you will know what needs replacing
Dec 21, 2011 | Washing Machines
I have water draining from the bottom of my front loader washing machine. It doesn't happenned every time. I have had the local repair man out cannot find the problem. I know its the machine because...
ok ,,take your time and get a flash light,,check the rubber gasket around front of tub for pen hole...giood luck,,if you dont find leak repost..and we will got to another step..pull on rubber tub gasket while searching..
Sep 09, 2011 | Maytag MAH8700A Front Load Washer
Water is leaking from inside the top back area of my refrigerator. I really need some help on trying to fix it. The leak is so bad that I had to put a towel on the the top shelve just so it doesn't...
The drain in the freezer side (behind back lower panel)
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Jul 23, 2011 | Refrigerators
I have a dodge grand caravan 1999. why would coolant leak from the bottom left corner of the radiato? it looks like the drain plug but wont do anything but leak all of a sudden as soon as i add coolant....
You need to look around, shine a flash light around the sides, top, bottom, and front and back of radiator, and around the radiator cap, look for any white or rusty brown stains. This should help you in your diagnosis. It is possible to leak from the drain but it would not just start out of the blue. If you are leaking from the drain there is another issue such as high pressure in the coolant system which could come from a failing thermostat or water pump, or a serious clogging problem.
Dec 11, 2010 | 1999 Dodge Grand Caravan
There is water leaking out of my bottom freezer
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Aug 11, 2009 | Candy CPCA240FFK Bottom Freezer...
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Amcor 14000 Portable Air Conditioner Logo
155 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
