Unbalanced spinning on a brand new Sanyo front loadingwasher - quite violent! Tried adjusting leveling feet - no improvement. Different loads of washing - same problem
Th packing screws were still in the unit and it prevented the drum from spinning!
Posted on Aug 07, 2008
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
In spin cycle violent vibration
First, check to make sure you aren't loading the washer excessively. Many times it is an unbalanced load. Second, check to see if the washer is level. The feet are adjustable and allow you to level the washing machine. While checking the level, make sure the floor underneath is stable as well. Lastly, if these do not help, you may need to have the dampners checked (these are like shock absorbers and minimize the vibration of the drum).
Apr 15, 2014 | LG WM-2277HW Front Load Washer
Severe shaking when spinning out
it could be you have to heavy a load or you do not have the washer level. Most washers have screw out feet that can be adjusted to keep them from shaking so violently the best thing to do is set a lever in different positions and directions on the top and level it completely and see if that does not fix your problem.
Dec 23, 2012 | Kenmore 44102 Front Load Washer
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Washer machise vivrates violently on spin
Is it a continuous thing? It could be that the clothes you have in there are unbalanced. Also, make sure the little feet at the bottom are leveled. Put a leveler on the top of the machine... you can also use a milk jug to try to gauge if its leveled.
Aug 11, 2010 | Maytag PAV2300 Top Load Washer
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
My front loading washer (ewf272el) spins violently during the spin cycle _ I am not overloading it.
When the wild spinning is not caused by unbalanced/overloaded (wet) clothes in side, the first thing to check is that the washer is propery leveled, with all 4 feet on the ground.
If that is not the problem, on a front loading washer, the next most common problem is failed bearings that turn the whole inside basket.
Please report back what you find, OK?
Aug 05, 2009 | EuroTech Washing Machines
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
Washing machine shaking on spin cycle
what is the brand of the washer along with the model nunber
Apr 12, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
