Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
I have a GE refrigerator (model #GSL22JFREBS) and it is making a constant clicking noise and the entire refrigerator is no longer working. Please let me know what you think the problem might be? Is it the compressor? If so, any idea how much to replace/fix it? Thanks!
    President:
  • 1,430 Answers
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine. All parts come with installation instructions. Not all models are available.
Posted on Mar 28, 2011
Testimonial: "Thank you!"
  • RS Mechanica Apr 16, 2011
    Hello all. I just checked out a GSH25JSRFSS side by side unit that was not cooling. There was a clicking sound coming from the control board(above the compressor compartment on right side). Start capacitor was good and compressor but compressor was hot. Cooled compressor. Found condenser fan motor was trying to move with every clicking sound. disconnected plug to motor and reconnected power cord. Compressor came on and clicking stopped. If you reconnect cond. fan motor it works and cools refrig. If you try starting unit up with cond. fan motor attached compressor does not work and clicking starts again( relay on board ). Is it a bad board or fan speed? Please let me know. Thanks. Only 8.6 volts D.C to motor.
  • 57 Answers
Unplug unit. There is a cover on back of unit. Behind it you will find a computer board. The clicking noise is probably coming from a relay on the board. I have found that this usually caused by a bad solder joint. It can be resoldered if finances are an issue. I would replace the board though. Good luck.
    Scholar:
  • 116 Answers
Hi this is the main motherboard in the back the board costs around $175.200.00 to buy if you put it in yourself, if you pay to have fixed will be around $330-400.00. This will fix your problem 100%. Take it from a GE guy :)
Sean
Loud noises in counter depth GE profile model pwe23kskess
refrigerators now a days have thinner cabinets & foam insulation, which resonates motor sounds . some high end refrigerators have added sound deadners which quiet the sounds somewhat.
Apr 27, 2018 | GE Refrigerators
I have a GE side by side refrigerator Model # GSH22JFTE CC that I purchased 8-25-2009. It ran almost constantly for the first several weeks (I was told that was the way it was supposed to do) In Oct. it...
hey i beleive u have a full one year warranty through ge ... so go online or call ge service geappliances.com set up a service apppointmont tell them its not cooling or sometin or whutnot lol or its making odd noises,, they will come out under waraannty and check it out .. hope this helps
Jan 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Fridge is making a clicking noise and Digital display out
Replace the mother board. (part # WR55X10942 )
Aug 21, 2009 | Refrigerators
GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
May 29, 2009 | GE Refrigerators
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Fridge making a noise
You have a bad relay on the mother board. It is behind a panel on the back of the fridge. You can view a diagram at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0432&modelDesc=REFRIGERATOR%20R%20SERIES&modelNumber=GSH25KGREWW&documentID=G0502132&documentTypeID=PLDM&documentClassCode=PV&titleType=SEALED%20SYSTEM%20%26%20MOTHER%20BOARD&titleID=00008& It is # 801. The part # is WR55X10552 and cost is $124.69 @ http://www3.sears.com/. I replace this board all the time. Make sure to unplug the fridge first!
Nov 03, 2007 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
504 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
