Question about Dishwashers
The clean light on my kitchen aid dish washer kept blinking and would not stop. after reseting it by pushing the buttons 2-3 times it cycles though and stops. then nothing works when i push the buttons. model : kudpo2crbl4
  • 57 Answers
The electronic control looks for a temp. rise of 2-4 degrees. If no temp.rise control assumes a heater fault and blinks clean light 7 times. Bad heater. Water fill when completed can be no less than 1/2 inch below heater. If so, water valve probably. Circulation motor not working properly. Neutral door switch. Tech sheet is behind bottom cover. Check underneath of unit for leaking or white hard water deposits. Common for seals to leak. If unit is unusually noisy, motor problem. Common after 4-5 years. Will check back to see if you other questions. Good luck.
Posted on Mar 28, 2011
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Apr 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
