Question about Kodak Office Equipment & Supplies
WHERE CAN I PURCHASE A NEW POWER CABLE / LEAD
    Problem Solver:
  • 17 Answers
Can one purchase a longer lead from power to television than normally supplied
Just purchase a mains power extension lead from any hardware store in the size you want. They usually start at about 3metres and go up in length from there.
Plug the extension lead into the power point and the power lead from the TV into the other end of the extension lead and there is your longer power lead.
Dec 23, 2015 | Televison & Video
How to install hard drive
First unplug power and leads including internet, then you will need a screw driver to get the side cover off, make sure to touch a bare metal piece to prevent static discharge. unclip the sata cable and power from the hard drive, unscrew the fixture screws holding the hard drive in place, remove and replace with new hard drive....or of you are adding another for extra storage look for a vacant bay to house the new drive, there should be a spare power lead for the drive but you may need to purchase another sata lead if you dont have one, attatch the sata lead to the motherboard then attatch the other end to the hard drive then the power lead. Close the lid and re-boot, the new drive should be picked up by windows 7 or vista, if you have installed a new drive with no operating system you will need a bootable op disc
Cheers
Sep 23, 2012 | Acer Aspire M3641 Dual Core E2200 PC...
Mic not working
Brand new:
1.Some microphones have a dynamic mic meaning it will work with all audio inputs
but this may have a condensor mic meaning it requires phantom power to operate.
your computer soundcard may not supply this.
so you need to purchase a phantom power injector.. there availible at most audio stores and electronics retailers.
if your unit had worked before but has since stopped:
2. Microphone lead/connection is faulty
if your feeling confident you will need to disasemble the unit and replace the lead
tools you will need:
screwdrivers,
multimeter
soldering iron
solder.
and some single wire shielded cable again availiable at most electronics stores.
just need to replace cable with new one and add a 3.5mm Jack to end..
hope this helps,ben
Jan 04, 2011 | Labtec AM-242 Microphone
LOST THE CONNECTING WIRED FOR THE LINKSYS WIRELESS ROUTER WERE CAN I GET A NEW ONE
Which lead do you need? a Network cable or the power or the lead to the filter into the phoneline?
Power - Have a look on ebay and see if somebody has a 2nd hand router going for sale, you'll probably find that buying a new router is cheaper than getting hold of a proper power supply from linksys. The other thing you could try is look next to the socket and see if there is a voltage and polarity symbol in which case you could try run it from a universal adapter with the same settings.
Network cables/Filters/Phone Line leads - Try ebay again or somewhere like http://www.cclonline.com/
Jan 21, 2010 | Linksys EtherFast Cable/DSL Router
Replace antenna
Remove old Antenna
  1. Activate the antenna switch to the up position.
  2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Gain access to the underside of the area of the trunk where the antenna is located.
  4. Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Remove the mast.
  6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Remove the ground lead from the panel.
  8. Pull out the antenna coaxial cable.
  9. Unplug the coaxial from the extension coaxial cable.
  10. Remove the original antenna coaxial cable. Note the route the cable follows.
Install new Antenna
  1. Inspect the fender area where the antenna mast will be mounted for rust.
  2. Clean the area before installing the new antenna.
  3. Plug the new antenna coaxial cable to the extension coaxial cable.
  4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  5. Connect the power lead of the antenna to the power antenna lead on the radio.
  6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  11. Stop the motor after the cable goes into the housing 12 to 25 inches.
  12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  13. Replace the retainer nut to the base of the antenna mast and secure tightly.
  14. Replace the panel that covers the antenna mount area.
Oct 16, 2009 | 1996 Honda Accord
Antenna mast broken
    Give these instructions a shot. Might be too generic but might be enough to get you going. Removing Original Antenna
  1. Step 1 Activate the antenna switch to the up position.
  2. Step 2 Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Step 3 Gain access to the underside of the area where the antenna is located.
  4. Step 4 Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Step 5 Remove the mast.
  6. Step 6 Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Step 7 Remove the ground lead from the panel.
  8. Step 8 Pull out the antenna coaxial cable.
  9. Step 9 Unplug the coaxial from the extension coaxial cable.
  10. Step 10 Remove the original antenna coaxial cable. Note the route the cable follows.
    Installing the New Power Antenna
  11. Step 1 Inspect the fender area where the antenna mast will be mounted for rust.
  12. Step 2 Clean the area before installing the new antenna.
  13. Step 3 Plug the new antenna coaxial cable to the extension coaxial cable. (On some General Motors and Ford cars you may need an adapter to mate the 2 cables together. Car audio retail stores sell such an adapter.)
  14. Step 4 Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  15. Step 5 Connect the power lead of the antenna to the power antenna lead on the radio.
  16. Step 6 Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  17. Step 7 Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  18. Step 8 Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  19. Step 9 Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  20. Step 10 Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  21. Step 11 Stop the motor after the cable goes into the housing 12 to 25 inches.
  22. Step 12 Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  23. Step 13 Replace the retainer nut to the base of the antenna mast and secure tightly.
  24. Step 14 Replace the panel that covers the antenna mount area.
May 13, 2009 | 1993 Chevrolet Corvette
Hi i have mislaid my lead that goes into my printer and the electrical supply can you please help and tell me what lead i need to purchase
If lead you mean power supply, I suggest you go to a computer store as they will most likely have a possible match. Most printer power supply leads/cables have a figure 8 female plug on one end and the plug on the other. The other lead/cable is the USB printer cable which you can buy at the computer store. If your printer is small enough bring it to the store to find a good match. If not I suggest you trace the outline of the female plug on the printer and bring it to the store. Hope this helps.
Jul 25, 2008 | Lexmark Office Equipment & Supplies
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
HP PSC 1317 All-In-One Printer coppier scanner.
This product looks to have an In-Line Transformer. This is where you plug a mains cable into a transformer (brick) which in turn plugs into your printer.
The mains cable is a standard three pin IEC lead, sometimes called a "kettle" lead. it is the same cable that you would use to plug in a monitor or PC. you can pick one of these up almost anywhere, most people tend to have a couple of these knocking around the house too as it is so common.
The In-Line AC Adapter is a little more difficult to get hold of, (you may be able to pick one up from ebay or just by searching online) There are 2 part numbers that I can find.
Q7310-60003 and 0950-4466 but they are essentially the same item.
Good luck
Dec 29, 2007 | HP PSC 1315 All-In-One InkJet Printer
202 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
