Question about Cell Phones
I have accidentally pressed 15712, which turns on automatic voicemail. How do i reverse
  • 31 Answers
To remove the voicemail diversion and return to your standard voicemail settings after the conference call, dial 15713 and press SEND.
Posted on Mar 28, 2011
WHAT IS 166:V.MAIL 02
Contact your phone service provider. Sometimes they accidentally switch off the feature. Mine was out for 4 months before I realised.
Jul 01, 2016 | Panasonic KX-T7453 Corded Phone
Deleted Voice Mailbox
u shoud go with a good fax repairer
Aug 10, 2008 | Comdial Impact 8012S Corded Phone
How do you put a Polaris Predator 500 in reverse
1. Place the transmission in first gear
2. Rotate the lockout switch forward to unlock reverse gear
3. Shift into reverse gear
When you shift back out of reverse gear, the lockout switch will reengage automatically to prevent accidental shifting into reverse
Mar 15, 2015 | Polaris 2006 Predator 500
How do you retrieve a voicemail message that has been deleted?
Unless your voicemail system has a "wastebasket" feature, you cannot retrieve an accidentally deleted message. It's gone. Not many VM systems have this feature. Cisco does, but Mitel low-end (embedded) models do not. The high-end Mitel NuPoint systems do. Older Avaya/Octel systems also do not. Contact your Voice Mail System Manager to find out what features your system has and how to access them. I've been away from this product for several years so features may also have changed. Hope this helps.
Feb 05, 2014 | Mitel Superset 4150 Phone
Used ctl,alt,page up to reverse screen....cant get it back!
Using keys on the lower right of the keyboard, reverse the process. For instance, if you accidentally pressed CTRL + ALT + HOME to turn orientation upside down, press CTRL + ALT + END to turn it right-side up. Likewise, if you pressed CTRL + ALT + PG UP, press its opposite, CTRL + ALT + PG DN.
Aug 10, 2013 | Computers & Internet
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
My phone goes to the answering machine even after i pick up the phone when i get a call.
You should check your call settings. Make sure that you do not have call barring turned on, also make sure that you did not accidentally set up call forwarding because then all your calls will be automatically forwarded to your voicemail. This should be in your settings under "call" or maybe "phone". You may also want to make sure you have the answer key turned on, or that your phone is set to ring multiple times.
Sep 06, 2011 | Uniden Cell Phones
I have lost my dish network remote but i have a universal remote i need the code so i can program my remote for my satilite
Here is a way with out the code.
1. Turn on the component (the tv, dvd, etc). 2. Press the TV (or DVD) button first and then the on/off button and hold both until the on/off button remains lit. 3.Press the PLAY button every five seconds until the component turns off.
  • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited
After the component turns off press the REVERSE button every 2 seconds until the device turns back on. Skip to step 7. 4.
  • If your television is an older model it may want to turn on immediately before you get the chance to press reverse. If that is the case and the TV automatically turns itself on then simply follow the step and keep pressing reverse until the component turns OFF. Then skip to step 7.
If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. 5.
  • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
6. To save the new code, press and release the STOP button.
Aug 24, 2011 | RCA RCR312W Remote Control
Voicemail
go to settings and reset ur phone is doing a same thing then u must enter this # (*2767*3855#)
Jul 01, 2008 | Samsung SGH-D900 Cellular Phone
I want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Oct 25, 2007 | LG Shine KE970 Cellular Phone
Cell Phones Logo
63 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
