Am really having a problem with my finlux tv.i wanted to reset the programs so i went to RESET PROGRAMS and after that everything got deleted.i want to install but nothing is working.please help me
    New Friend:
Cant restart ny finlux tv after a programwareupdate....What can i do?
Posted on Apr 03, 2013
Obertelli
  • 3006 Answers
SOURCE: hi, I have a vistron
If you want to watch Freeview, then you need an aerial, preferably a proper external (or loft mounted) one. Freeview signals are far weaker than traditional tv signals and so trying to receive them without an aerial or via a tv set-top aerial is usually doomed to failure. If you must use a set-top aerial then connect it directly to the tv (not via a video or any other device) and avoid using "amplified" or "booster" aerials unless you have no other choice.
I'm unfamiliar with Vistron, but usually channels are added by going into the menu and looking for "installation" or "set up". But if you have no aerial then you aren't going to get very far.
Posted on Sep 03, 2010
  • 47 Answers
SOURCE: Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
Posted on Jun 25, 2009
  • 362 Answers
SOURCE: black screen
Hi katie_wood21,
About 80% of lcd tv failures are due to the backlight inverter, I suspect that is your problem.
An easy way to check it is:
  1. While tv is on and you have sound.
  2. Shine a flashlight on the screen.
  3. Loook very closely and see if you can see a video image.
If you are able to see video you have a backlight inverter failure.
If the tv is still under warranty you should begin the return or replacement process now. If no warranty you can take it to a local tv shop and pay about $250 to $350 for the repair, or you can repair it yourself.
Let me know your findings and I will assist further.
Please rate this solution, I know I didn't deliver good news but I gave you the truth without a big run around.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Apr 18, 2009
  • 24 Answers
SOURCE: Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
Posted on Feb 11, 2008
TV #1
  • 129 Answers
SOURCE: I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Posted on Dec 07, 2010
My tablet is running extremely slow since I downloaded some programs. How can I delete these programs to fix this,with out doing a reset?
Hi! The reason why tablets running slow when we install apps or programs is because of its low memory. What we need to do is to uninstall or delete the apps we don't need and just keep those we really need.
To delete or uninstall a program we need to:
1. Head on to the Settings.
2. On the settings we can see the Application Manager tab, then click it.
3. Find the program you want to delete then click it.
4. From there you can see 'Uninstall', click it and then click 'Yes'.
alternate solution:
1. You can directly delete the program from your application menu. Just by long pressing the program's 'icon' that you want to delete, then hovering the icon to the word 'Uninstall', and then it's done.
Hope this will help. :)
Aug 17, 2017 | Computers & Internet
My TV keeps flicking from one channel to another my TV Is a finlux
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 11, 2017 | Finlux Televison & Video
When plug tv in it keeps turning on and off and nothing I press or do will stop it finlux 42"3d smart
Try a reset to this TV and check. If it do not help you, its main board is faulty. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 20, 2015 | Finlux Televison & Video
My finlux 39 inch led tv is stuck on standby can anyone help
Do a reset to this TV and check. If it do not help you, the main board to this TV is faulty. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Finlux Televison & Video
I have recently had internet explorer 11 installed I need to reset it
Don't try to reset a program. There are nor reset buttons for programs. If you have trouble with a program like IE 11 , try to reinstall it, Or just put in your Windows DVD restart the computer and say you want to install windows. Windows sees there is already a version on the computer and will ask you to install windows, or to repair the existing version. Chose the last one, repair.
Other programs, you could reinstall and then reinstall from scratch, But IE is one of the programs you can't uninstall.
Never try to delete programs in windows, because you could delete the main program, but lots of extra files and links, can stay active, missing the main program. But also the registry, will have unused entries, that can't find the programs they are pointing to.
So in Windows, if you don't want to use a program, uninstall is the only way to get it from your computer.
Sep 22, 2014 | Computers & Internet
How do I delete program times for the filter pump on the Aqualink rs8 panel?
These are great systems: Go into "MENU" (MENU BUTTON) Scroll down until you see "MENU/HELP" Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS" It will say "PROGRAM 1 of 1" that is what you want - Hit enter - This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times). ***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
Dec 07, 2010 | Jandy Pool & Spa
Reset the format & reset function on my camera, and now I can't see any of my pictures or videos on my memory card?? Please help me retrieve. It did not ask to delete anything.
I'm afraid that formatting a memory card deletes everything on it. You may however be able to recover the files.
First take the memory card out of the camera. Pictures that have been deleted are probably still there, but will be overwritten if you take any more pictures on top of them.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the deleted files. Undelete programs are available for free download from the internet, try at www.download.com. Not all of these programs work with memory cards, and not all of them can recover files from "drives" that have been formatted. You will have to search a bit to find the right one.
If the pictures are very important to you, you might want to seek help from an experienced person.
Nov 16, 2010 | Samsung L100 Digital Camera
My internet explorer just went away and effects my c drive is there a way to reset to factory defaults
You can reinstall the Internet Explorer's latest version from HERE So now you have internet Explorer.
But if you really want to reset C drive you should format the drive but just to let you know it will delete everything you have in C drive - For Example your programs and probably your OS.
Even then you can reinstall the whole OS from the CD or DVD that you received when you bought a laptop. And your laptop would be as good as new but if i were you i would backup all my data in External Hard-disk or any Peripherals that uses to store data.
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | Dell Latitude D800 Notebook
How do you reformat the hard drive for hr-20/700
If you go into the DVR's Menu/Setup there will be menu selections to "Restart Receiver" and "Reset Receiver"
In the reset menu you should find three options "restart receiver" which is roughly equivalent (and possibly safer) than the reset button or a power cycle. "Reset defaults" will clear all of your preferences and personal setting without affecting recordings. "Reset Everything" pretty much returns the receiver to ground zero and deletes everything.
Apr 26, 2010 | Directv HR20-700
Can't delete a program EM-500
If all else fails... Just do a hard reset...you know, hold down the power button and pust the reset button in the hole on the back side of the casio....of course you will loose everything you've installed and will have to reinstall, but sometimes that seems to be the simlest way.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Televison & Video Logo
821 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
