Question about Daewoo KOR-630A Microwave Oven
Hai my daevoo microwave only display & light working. not heating wat happent
  • Daewoo Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 14, 2011
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
My daevoo microwave ,the light is working but know heater for the food the turntable gous round we had it about over 12 mounths thankyou
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 07, 2011 | Daewoo Microwave Ovens
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Micro wave is not working
don't know about the red light, but (fancy this) I had the same problem with my microwave tonight. Everything but heat worked. Unplug it, plug it back in. Worked for my GE Spacemaker.
Jan 27, 2009 | Emerson Microwave Ovens
Daewoo KOR-630A Microwave Oven Logo
95 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
