Question about Mitsubishi XL9U LCD Projector
Hi i cant get my dvd player to work with the projector? eveything is in the right place. so what do i do now?
  • 4 Answers
How are you wiring it up? Yellow, White Red (RCA?) or Red Green Blue? or SVideo. Also make sure your projector is switched to the appropriate input.
Posted on Mar 28, 2011
I cant eject the DVD. It keeps saying "Please
Try pressing repeatedly the eject button while you turn on the unit. If this doesn't work then it is a mechanically problem in your player.You need to be manually open to take out the dvd.The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Furthermore, if the belt is slipping, the mechanism never gets the "drawer closed" signal, and the disk will not spin.
After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. So it indicates the defective laser motor. The only way to fix this problem is to bring the unit to a service center for repair.
Hope this helps.
Please feel free to ask us if you have any further queries.
Shane
Feb 13, 2011 | Kiss Technology DP-600 DVD Player
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
I cant play my dvd on my infocus LP280 projector
Please provide us with more details like the DVD player make/model and what is the connection cable you are using.
Normally, you should be able to connect the DVD player through the AV out pins and connnect it to AV in of the projector.
Other options that can be used are:
S-Video connector, component video connectors, and DVI-D connections
Please reply for more help and clarifications. Thanks.
Aug 05, 2009 | InFocus Office Equipment & Supplies
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
YPbPr and YCbCr signal
with component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Feb 26, 2009 | LG RD-JT30 Multimedia Projector
Why has my portable dvd player's picture become unclear?
I'm going to get a cleaner disc and in the meantime, my husband bought me a new portable dvd player. Thanks for the space and your time, C.
Jan 08, 2009 | Televison & Video
Projector signal goes bad after 25 minutes
It appears the projector was over heating. Why it affected the DVD signal and not the computer signal, I do not know. The other confusing thing was the projector was hanging off the ceiling and should have had plenty of circulation. When I climbed up to check for excessive dust, I found that the lens cap had been placed over the intake vent. I blew off the dust and removed the cap. After running the projector for an hour, it appears that the problem has been solved.
Sep 22, 2008 | Dell 4100MP Multimedia Projector
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at) gmail.com
May 17, 2008 | Samsung Televison & Video
Projector turns off after 35-40 minutes
i have the same problem with my projector it sudden turns off, and it has a blue stipe on the bottom of th screen. is this a sign that my blub is bad? or is it the power supply that is damaged? it can be on for days without any problems and then they come and go..
Mar 12, 2007 | Canon LV 7345 Multimedia Projector
Mitsubishi XL9U LCD Projector Logo
63 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
