Question about Cameras
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
  • citroengirl Nov 23, 2008
    same problem
  • cardonaconce May 02, 2009
    memory card error c 13
Posted on May 27, 2009
Posted on Aug 07, 2008
Camcorder won't read the memory stick
cara memperbaiki hendicam buram gimana gab ?
Dec 15, 2013 | Sony Handycam DCR-HC30 Mini DV Digital...
When turned on, says "memory card error! reinsert
Remove the card from the camera and use the card reader on your PC to scan the memory card. It is possible there are errors on the card. If so format after copying all the files from the card. Now if the camera shows an error the fault is with an interface issue with the motherboard. make sure that the card holder tray is clean, blow air to dispel any dirt and also try with another card to confirm the case.
Oct 24, 2011 | JVC GZ-MC500 Memory Card Camcorder
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Just bought a 16gb sony memory stick pro duo magicgate mark2 memory card for my sony t900 digital camera. pluging in the memory card it says reinsert card and a error code c:13:01 can u help
Hello. There several causes for this error code from bad card to bad camera. Some of the Chinese cards are counterfiet copys and could be a problem. Try rubbing the contacts on the card with a pencil eraser to clean them up. wipe with a clean cloth and try again. Try the card in someone elses camera to see if it works. Leave a message here if it still doesn't work , I'll look around some more.
builderdale
Jan 21, 2010 | Cameras
Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony will not read 8gb Sandisk memory card. States, Reinsert memory card and flashes c:13:01
Check your owners manual...can your camera handle an 8gb card? Maybe all you need to do is format it in the camera.
Oct 06, 2009 | Sony Cybershot DSC-T200 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
I have a digital camera that keeps telling me to reinsert memory stick (error C:13:01)
The memory stick could have failed as could your card reader. If it is the card reader you're looking at $75-$100 to repair
Dec 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Cameras Logo
2,252 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
