Question about Learning Resources Teaching Cash Register LER2690
Our register appears to be locked or jammed. Is there anyway to reset? We have replaced with new batteries. No functions occur. 3 lights are on and that is it. When we press a button nothing happens. This has never happened before.
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
Tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 | Refrigerators
Black copy problem
Subject: Full page solid image or error code C3200
Model: FS-6025MFP
Phenomenon: A full page solid image may appear on the print-out or error code C3200 (Exposure lamp
error) may occur.
Cause: The digital transistor in the CCD power supply circuit at the main board may be damaged,
resulting in the CCD failure.
Field measure: When the above mentioned phenomena occur, please replace the Main board with the latest type
(Parts PWB main assy).
Nov 02, 2014 | Kyocera FS-6025MFP Laser Multifunction...
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
After paper jam printer displays error light and will not function
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Error code E94 paper jam
I used compressed gas duster to clean the resgister and it worked. It is called Duster Destroyer and I got it at the Staples for $9.99
May 30, 2008 | Casio Parts Cash Register PC Desktop
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Learning Resources Teaching Cash Register LER2690 Logo
163 people viewed this question
Top Learning Resources Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Learning Resources Toy Expert? Answer questions, earn points and help others
