Question about Garden
I just need a diagram to see that I am feeding the wire through the driving mechanism properly. I lifted the cover and there is not a diagram shown there.
    Scholar:
  • 54 Answers
If this a MIG welder be very careful and download a drawing from the manufacturer, a bent mig wire if it is very old stock and resin core to boot can snap and go through the cable into your arm, possibly discharging the torroid energy into you.
Posted on Mar 29, 2011
Drain stuck in closed position
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Mar 22, 2017 | Maax Plumbing
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Doc feeder is not working right. Paper jams. If you lift the lid up the document will pass through OK, just won't copy right.
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Oct 28, 2010 | HP Officejet Pro L7680 InkJet Printer
How the heck do you get the side panel off Sony
From the Sony manual:
http://www.docs.sony.com/release/PCVRX670_SR.pdf
Removing the Side Cover
You must remove the side cover to access the system board, add-in cards,
power supply, battery, memory, and internal drives.
1 From the rear of the unit, pull the metal tab shown in the next
diagram. (Upper right corner)
2 Pull the top of the cover away from the unit about two inches, then
gently lift out the cover.
Aug 01, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Feb 25, 2010 | Hobart Welding Tools
Have t104, wired properly 220v feeding the timer,but the clock motor does not turn?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
here is the link for the wiring diagram, u need to make sure u have it hooked up to the right terminals.
if u do, u need to make sure u have the wheel in the right position for it to turn, if its in the position to set the time the motor won't turn it.
Aug 15, 2009 | Intermatic T104 24h 208-277v Mechanical...
I have a 1979 harly davidson soprster, i have re
There is no need for a resistor of any kind. The light should be run with the feed coming from the power breaker and the ground side connected to the “A” post of the Generator. Resistors were added by some companies to prevent the light from flickering at low RPMs. If the Generator is working properly there is no need for a resistor. Be sure to polarize the generator properly as failing to polarize the generator is the most common cause of a Gen light that won't go out.
Jun 20, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Power led blinks - canon pixma pro9000
Your canon printer needs to be serviced. That error is treated with special lubricant applied to a cam assembly inside and above the sheet feed assembly.
Mar 22, 2009 | Canon Office Equipment & Supplies
There is a paper jam in the ADF... I have a hp 2840
The top cover piece at the left-hand end of the ADF just lifts up. Put your fingers under the edge where the paper feeds into the ADF reader and lift gently on only the plastic cover itself. It is hinged on the leftmost outside of the reader mechanism. Once that cover is lifted then the main feed roller is exposed, and it also just swings up out of the way to the left to provide easy access to the feed path. You will likely also have to lift up the entire ADF to gain access to the flat glass flatbed read platten area to access the remainder of your original.
Dec 08, 2008 | HP LaserJet 2840 All-In-One Printer
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
