I have the siemens rev11 and struggle to change the clock . I set the cursor on the time position but when pres the up and down buttons , it doesn't react and the time stays the same.
  • ekuehnel Mar 29, 2011
    Hello
    I have done that , but as the time doesn't change in the first place nothing happens when I slide it back to the auto position. I have also tried by resetting the themostate and I get the same problem. I can change the programmed time so it's not he +or -, it's that the time position doesn't seem to be working.
  • JEANNETTE MISSONS Jan 22, 2013
    I've changed the batteries on the rev 11 now nothing appears on the screen ?
    Guru:
  • 1,833 Answers
It seems like your Siemens rev11 system malfunctioning. The main problem is you can't set the clock, somehow it is not working. There is no step by step instructions that can help you. Though you can visit this web link, where you can find manuals and customer service e-mail id, and see whether it can help you :
http://www.heatingcontrolsonline.co.uk/guides.html.
Posted on Mar 29, 2011
    President:
  • 1,932 Answers
Hey
make sure you move the setting slider to the time position then press + or - to set the time move the setting slider back to the previous position after this is done and close the cover.
hope it helps
Posted on Mar 28, 2011
How do I reset the time on my camera? Olympus C-500 Zoom
Set the mode dial to P and turn the camera on. Press the OK button to bring up the menu. Press cursor-right to select the MODE MENU. Use cursor-up/down to select SETUP and press cursor-right. Use cursor-up/down to select the clock icon and press cursor-right. Use cursor-up/down to select the format and press cursor-right. Use cursor-left/right to move between the fields, cursor-up/down to change their values. Pres OK when done.
The above is from pages 29-30 of the reference manual. If you need manuals for the C-5000, you may download PDF versions and/or order printed manualsfrom here.
Jun 20, 2012 | Cameras
How do I reset the time on my C-5000 Zoom?
The above is from pages 29-30 of the reference manual. If you need manuals for the C-5000, you may download PDF versions and/or order printed manuals from here.
Jun 20, 2012 | Olympus Camedia C-5000 Zoom Digital Camera
I need to reset the date and time to the correct date and time. Cannon A520
Press the MENU button and use cursor-right to select the wrench-and-hammer icon. Use cursor-up/down to select the clock-and-calendar icon and press the SET button. Use cursor-left/right to move between fields, cursor-up/down to change them.
Full directions are in the "Setting the Date/Time" section of the manual (page 22 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Jul 17, 2011 | Canon PowerShot A520 Digital Camera
Nable to set date on Sony DSC-S40 Camera
Press the MENU button. Use the cursor keys to select "Setup2" and then "Clock Set". Press * at the center of the cursor pad to enter the setting. Use cursor-up/down to select the format and press *. Use cursor-left/right to move between fields, cursor-up/down to change values. Set each change with *. When done, use cursor-right to select "OK" and press *.
See "Using Setup items" in the User's Guide (page 41 in my copy) and "Turn the camera on/set the clock" in the Read This First for full details. If you need either document, you can download it from
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCS40
Jun 09, 2011 | Cameras
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
I dont know how to set time and date on the camera
Press the MENU button, then use the cursor keys to select the Setup menu (hammer and wrench icon) and press the OK/FUNC button. Use the cursor keys to select Date (clock icon). Use cursor-up/down to change values and cursor-left/right to move between them.
May 21, 2010 | Olympus Stylus 7010 Digital Camera
How do I change the time on m Siemens Microwelle plus oven please? Model number HF75960GB
Did you try pushing the clock button, setting the time (eg. 300) for three o'clock, and then push the clock button once more. If this doesn't work, don't push the clock button at the end. Just set it, and let it stay until it stops blinking - and then it should be set. If you need further assistance, let me know and I'll help you. I'm just going by the usual standard of setting clocks on microwave's - but maybe with this model, there's another way. Good Luck to you! - Jim
Mar 28, 2010 | Siemens Microwave Ovens
One Motorola Mobile W270, Model SM1006AE7U1 / W270 BLACK ENG/RUS purchased from DUBAI last week. The cell shows some language not known to me. Will you please guide to set the same as ENGLISH ? B C Tiwari,...
Hi
Thanks for using FixYa. To s
et the English language: Go to Menu->press (down) cursor 7 times-> press right soft button-> Press (down) cursor 3 times-> press right soft button->press (down) cursor 1 time-> press right soft button-> Press (down) cursor 4 times-> pres right soft button and now select language as English.
Another simple way is to go to settings and go to phone settings and from there select language setting and select English settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 13, 2010 | Motorola Cell Phones
Want to change keyboard clock
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Sep 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Jan 07, 2008 | Audio Players & Recorders
Heating & Cooling Logo
268 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
