Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS267LBSH display not working
The display has iluminated only one led of the whole display, and is not working the ice machine neither the "CoolSelect Zone" section.
3 Suggested Answers
  • 119 Answers
SOURCE: Samsung RS267LBBP 26.1 Cu. Ft. icemaker won't stop making ice
UP.
Posted on Aug 07, 2009
SOURCE: de icing the freezer in a Samsung SW 2630WW
Take all of the shelves out of the freezer side. Take to Philips screws for backing and 4 philips screws from vent cover just above cover. unplug, Use a hair blow dryer and melt it. Put it back together and there you go. Whole operation from start to finish is about 15 minutes.
Posted on May 20, 2010
Samsung RS267LBSH/XAA evaporators (both the refrigerator and freezer sides) building up with frost. It works fine for about a week after defrosting with blow dryer, and then same problem happens.
Your defrost heaters are not working. The unit takes a week to freeze up and presto - poor cooling. Melt the ice and it works fine again till it freezes up again. Did you check out the defrost timer? Make sure that the defrost elements are not open.
Apr 30, 2017 | Samsung Refrigerators
Why would the LED indicator light illuminate for the water and crushed options, but not for the Ice option. The icemaker is working and dispensing ice.
I appreciate your post, Cindy!
From what you have described your LED indicator will light for water and crushed option but not for the ice option on your Frigidaire refrigerator. This could be a possible issue with the light on your display. Unfortunately you are unable to change out the light and the whole display would need to be exchanged. If you need assistance replacing the board I would recommend seeking help from a professional technician. -Matt
Aug 12, 2015 | Frigidaire FGHF2366PF French Door...
My samsung ice maker is making ice, but not dropping it, what can we do?
http://www.appliancepartspros.com/samsung-assy-cover-dispenser-da97-08118p-ap5651766.html
This is your Touch pad. On it using only two fingers (nothing else touching the fridge) Press and hold energy saver, and the lighting button at the same time for 5 seconds. All of the LEDS should flash on the display, this is error code mode. Hold it down until either all of the LEDs go blank, or unless one of the little temperature lines start flashing. If they do flash you probably need a new ice maker. If they don't, honestly, it still sounds like the control is still working because it's supplying the ice maker with power. If the display goes blank for 30 seconds, the fridge will reset causing it to start operating normally again, but it always feels good to see if the unit will actually throw the error code for you. DA97-08059A is the part number available here..
http://www.amazon.com/s/ref=nb_sb_noss/183-7769407-3742050?url=search-alias%3Daps&field-keywords=DA97-08059A
Before ordering this part, also verify the freezer is cold enough (-8 all the way to 10 degrees F will be cold enough for the fridge to induce a cycle of the ice maker, any warmer temps this will not work. If the ice maker doesn't solve the problem, Then we point the finger at the main board, but have never replaced the board on this model to solve this issue. These ice makers fail enough to keep a truck stock one at work.
Jan 31, 2015 | Samsung RS263TDWP Side by Side...
Polaroid rc 103 wont program
please use this secret take you r. control point upward the digital camera( you must get one) turn on the camera and from the display you must see the diode LED iluminating. see the picture ilustration. If not working you must open the r. control and clean the keypads for dirty, corrosion, grease. fix it.
Feb 19, 2013 | Polaroid 1720-7 Remote Control
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Saeco incanto Sirius led screen flashing
Electronic parts don't like water - propably you have to change LED which is iluminating tej panel
Jan 06, 2012 | Saeco 00034 Incanto Sirius Super Automatic...
Model RS267LBSH/XAA - freezer working but refridgerator side warm (54 degrees). Heard sound like fan blade hitting, then no longer hear fan at all. What could it be
Have same model rs267lbsh/XAA and fix refrigerator. What I did was take off cover where evaporator is there a wire called defrost temperature sensor that goes bad I changed that sensor and my fridge is now working .if u need to ask me question please email me at jwilliams1957@sbcglobal.net
Apr 12, 2011 | Samsung Refrigerators
I just replaced my fan motor in the Samsung RS267LBSH side-by-side. The fridge is still not cold. What is going on?
OK I will need more information on what is happening with your Samsung. Are you getting cool temperatures anywhere inside your fridge? Which fan motor did you replace and why? Are you having trouble cooling inside the Fresh Food compartment or the whole refrigerator? Is the compressor running? Do you feel warm air coming from below refrigerator? Answer as much as you can here and I can also post answers here=> Appliance 911 Any detailed photos or Samsung info will need to be exchange here=> appl...@yahoo.com due to their copyright rules. I am here for you the customer and Fixya and will be happy to assist you to the furthermost extent even to the point of contacting Whirlpool that now owns Maytag, Samsung and many other brand names, Thanks, Sea Breeze
Jan 24, 2011 | Refrigerators
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Dec 03, 2009 | Samsung Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
83 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
