Question about Whirlpool Microwave Ovens
Our beko dwd540w doesnt wash properly every wash the plates and cups ect have bits on them
  • 2,510 Answers
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Mar 28, 2011
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I...
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Nov 23, 2013 | Microwave Ovens
Doesnt always make a full cup of coffee sometimes it doesn't even make a cup. Machine i s less than a year old.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Microwave Ovens
My bosch washing machine is leaving a grimey residue in the drum after the wash. I have tried to run the machine without any clothes to see whether it was simply not emptying properly but that's fine -...
This bosch washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Bosch Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
The plate of my microwave own doesn't turn
Turntable motor must be replaced.
May 28, 2010 | Microwave Ovens
Plate getting too hot
I don;t think your plate is micorwave safe. Put the plate and a glass measuring cup with water in the microwave for 1 minute, if the plate is hot and the water is not the plate is not microwave safe. IF the water is hot and the plate is not. I don't know what the problem is
Sep 16, 2008 | Kenmore Microwave Ovens
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
