Question about Garmin Nuvi 780 4.4 in. Car GPS Receiver
Hello. I have a problem that no one has seemed to be able to help me with. All i get is a dumbfounded look or scratch on the head. I have a Garmin Nuvi 780 GPS for the car. I do not have a cigarette lighter in the vehicle to power the GPS when the battery dies in it. This GPS does not have a user replacable battery for it. Yes i know i can buy one and unscrew and pry the GPS open and replace it but i dont want to do that every time the battery dies. What i am looking for is a portable power supply i can take in my vehicle that has a receptacle that i can plug the car charger made for my GPS into to. I tried the Gomadic rechargable battery pack and it was a joke. Will be sending that back. All i want to do is to be able to navigate while my GPS is plugged up to something to get power to it. Can anyone tell whay i need and where i can get it. I would very much appreciate it. JoAnn
  • 1,514 Answers
Hi JoAnn, What you really need is a cigarette lighter socket in your car and this doesn't have to be a big problem. In most car accessory shops you can get cigarette lighter socket splitters, like the one at http://www.amazon.co.uk/Silverline-Cigarette-Lighter-Splitter-Adaptor/dp/B003TNYK7Y/ref=sr_1_1?ie=UTF8&qid=1301407423&sr=8-1
Now I know these are supposed to plug into your cigarette lighter socket but you can remove the plug from the end of it and get wired directly to the fuse board of your car. The wire that goes to the centre tip of the plug connects to the positive/fuse of the fuse board and the wire that's connected to the outer part of the plug connects directly to an unpainted metal part of the car. You can do this by loosening a bolt, wrapping the wire around it and tightening it again. The block with the sockets on it can be either glued with double sided tape to a convenient part of your car interior or left loose if you prefer.
If you're not happy wiring it directly yourself it should not cost a lot to get done in a garage. If I was in your position that's what I'd do.
Posted on Mar 29, 2011
Head lights and radio stopped suddenly
check all fuses in fusebox, simple but often the simplest things are the ones that dumbfound us!
Sep 07, 2012 | 1989 Geo Tracker
I have a new Garmin 410 and really struggle to get it do download via the ANT agent.
Once the USB ANT Stick is connected it should automatically start downloading.
Make sure the Garmin Communicator Plugin is up to date for Mac OS.
http://www8.garmin.com/support/download_details.jsp?id=3739
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 11, 2011 | Garmin Forerunner 410 with Heart Rate...
I cannot register my garmin nuvi 1450LMT. I have followed the instructions - and get part way, but seems the connection between Garmin and computer will not connect. HELP!
The Garmin Communicator Plugin will need to be installed on the computer.
http://www8.garmin.com/products/communicator/
Also, you may want to check the data cable and that it is the proper one.
It should be Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin Nuvi 1450LMT
I want to register my new nuvi 465lmt my problem is that I cant seem to find how to register my gps
Registering your Garmin GPS device is a very easy process, I have written up a tutorial you can find it here at this link.
Hope this helps!
Apr 09, 2011 | Garmin GPS
My interior speaker not working how do i fix it
hello there are 6 tabs holding the case together, 2on each side. once the screws are out, i just run my finger nail allong the seem to unset them. but if you have a small plastic flat head screw driver this will also open the tabs goodluck
Mar 27, 2011 | Garmin GPS
Hello, I have a model 1350 and it seems locked up and will not recieve satilite signals?
Try giving your unit a firmware update using Garmins WebUpdater software, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp. If this dosent work your units GPS receiver is probably dead and should be sent in for repair.
Hope this helps!
Feb 18, 2011 | Garmin nvi 1350T 44 in Car GPS Receiver
Can I delete individual addresses on my Garmin 855? " Delete all" seems to be the only option. Also can I moveindivual addresses to favorites? thanks
Unfortunately you can only clear the whole list of recently found items.
Saved addresses and favorites can be removed 1 at a time.
Hope this helps!
Feb 11, 2011 | Bass Pro Garmin 855 4.4 in. Car GPS...
I have a portable dvd player that is now not wanting to play any dvds. it will just keep saying its loading. But then if the dvd decides to work it'll play for a little then freeze, it seems like the dvd...
its probably the laser head try to clean maybe it has some dust <br /> if it will not help maybe need to replace the laser head <br /> If you want to fix the portable DVD write to me , <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Aug 26, 2010 | Televison & Video
UPDATE TROUBLE
First thing to try is to stick the disc into a PC. It will either read no disc, or ignore that there is a disc there; or it may load the disc fine and either autorun or come up with a "what action do you want to take/disc format not recognised" type of message. If a PC will not read the disc, first check it visually for scratches - in particular near the centre, and especially if the scratch is going around the disc not across it. If nothing big visible, then try cleaning the disc with a soft damp cloth, a little water and some detergent - if you have to rub, go from the centre outwards not round and round. Try the disc again in your Garmin. If this doesn't work, check the foil side of the disc for damage - look real close. If there is any, then there are not many ways to fix it that are often successful or that will last for long. next to see is if you can polish any scratches out. Use a fine abrasive polish like Brasso with a soft cloth (not on the foil side). Start with the worst looking scratch, see if it will soften or polish out. Try the disc, then keep polishing each scratch in turn to see if you can get it working. You can buy little machines that do similar by polishing the whole disc, but they are normally more agressive than you need if scratches are the problem. If still no luck, then try Garmin for a replacement CD; http://www.garmin.com/garmin/cms/site/us/supportcontacts sorry I couldn't find any details on their site now (it's a huge site), but they used to replace damaged discs so long as you paid the postage and sent them a damaged legal copy first. Possibly now they do the same by download - check with them for a quick answer - their service is normally good. Please ask again if you need more info. Hope this helps :)
Aug 07, 2007 | Garmin StreetPilot i5 GPS Receiver
Garmin Nuvi 780 4.4 in. Car GPS Receiver Logo
89 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
