Question about Linksys WRT160N Wireless Router
Im constantly having to push the center button on my router for it to connect. i have no problems with the wireless aspect, my xbox live works fine in the other room. my desktop is connected via ethernet and im tired of having to refresh the router
    Problem Solver:
  • 11 Answers
I was facing a similar issue a while ago when I stumbled upon www.ijinni.com. The site was exceptionally well laid out and easy to navigate. All I had to do is, pose my question. The resolution was provided very promptly. They offer some excellent technical guidelines which cover a wide range of topics from installing network drivers to cleaning your mouse JUST FOR $10. So if you are looking for online technical support for any kind of computer related issues with knowledgeable specialists who come up with perfectly acceptable solutions, www.ijinni.com is the right pick.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just add the contact "ijinni.com" (free call).
3. You can email at support@ijinni.com
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call IJINNI
Clean, straightforward and effective!
Posted on Mar 28, 2011
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Constant red light now on my xbox wireless adaptar after working
my first suggestion is check your setting to make sure everything correct. to be sure re-enter everything if you still have problems. I would then check if the adapter can read your router (this can be done by searching for a signal). if the router is found and can connect but failes connecting to internet your router itself may not be connected. make sure your router can connect by itself and that you can connect to internet through the router from your computer. if all these steps are takin try config your router so it will accept incoming signals and that it has the right security for the xbox to connect.
Feb 02, 2010 | Microsoft Wireless Network Adapter Xbox...
When i host a game on xbox live, The whole games lags up and i get kicked, I never used to have this problem, And i have 10meg BB is this a router problem? When im not the host i can play fine, Usually...
Is your Xbox hard wired or wireless? If its wireless, try changing the broadcast channel (to like 11) your are probably getting interference. If its hard wired, you probably need to forward the port on that IP address for the Xbox
Nov 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Xbox 360 sony laptop media center problem
The firewall on your laptop may not work and/or you may need a software update either on the pc or xbox
those are the most common
your set up is ok
Sep 27, 2009 | Microsoft Xbox 360 Console
Xbox live cannot connect to network
I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
Jun 30, 2009 | Linksys Wireless-G WRT54G Router
Cant connect to live...wireless.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 setup
it way be that your modem and/or router does not recognize the ethernet cord. the contacts on either the cord or port might be fried. try plugging the xbox cord into the laptop port if the laptop is hooked up by cord or try using a wireless adapter for your xbox if the wireless seems to work fine with your laptop.
Oct 11, 2008 | Microsoft Xbox 360 Console
Prolem with xbox
well if it IS working, you wouldn't be here would you? XD
anyways go to the wireless settings and manually add your SSID and WEP/WPA if applicable. If this doesn't work, get back to me.
Jul 31, 2008 | Microsoft Xbox 360 Console
WRT54G xbox live DNS fail
log in to your router and forward ports in the router, call 1-800-linksys they'll assit u to fix your issue,
Feb 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT160N Wireless Router  Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
