Question about Watches
Need to put my watch one hour back, how to do it?
I am having a citizen eco drive watch Once i put it under a fluorescent lamp for charging After couple of hours when i checked the watch was struck with second hand at 15 second. It is no working
I have one as well. Sent it back to Citizen and they told me it just needed charging.
I find it only charges in direct daylight and it takes up to 12 hours to start to recover and then another day to work properly.
I shall never buy another one!
Mar 12, 2017 | Citizen Watches
Putting watch hands back one hour from bst
pull stem out and rotate counter clockwise or wait the hour and push it back in
Oct 30, 2016 | Watches
I have a Pulsar watch need to change to day light saving time
just put the hour hand forward or back 1 hour
Mar 15, 2016 | Pulsar Watches
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
I purchased one Seiko Sports 100M watch from Noida in Feb and from day one it is not functioning properly. The watch stops in 8- 10 hours even after a continuous use of 12-14 hours. I have given the watch...
Take it back to the dealer and insist that he takes it back and gives you either a refund or a replacement.
It is clearly faulty and it is his liability to put is right.
Apr 14, 2011 | Seiko Watches
Ineed to put my time to winter time ie 1hour back
on the left side of it u will find a mode button........prees it till the time starts blinkinthen reset it usin the reset button.....adjust how u wan......u r done with ur work....thank u
Oct 30, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 01, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Need instructions or a manual on how to stop beep mode on watch
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
Mar 26, 2009 | Watches
Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Chris
Jun 17, 2008 | Bulova Men's Watch
Watches Logo
13 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
