Question about Whirlpool Washing Machines
Whirlpool washer model LSQ8000LQO... serial nu CP1418493 type 111. will not spin in spin cycle
  • 57 Answers
Most common is lid switch.
Posted on Mar 28, 2011
Whirlpool type 111 washer drains won't spin. makes loud screeching noise. installed new clutch assembly. still no spin.still high pitched noise (like a belt slipping) but type 111 is direct drive
Belt slipping? is the wash tub free to turn when empty? socks and small clothing items may be jammed in the drum / tub cavity caused by overloading if its stuck. May need to strip machine and remove drum to get them out.
Don't overload machines!
Feb 03, 2018 | Whirlpool Washing Machines
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
I have a Whirlpool Ulitimate II Washing Machine problem. Model LSQ9010KQ0 Serial CM2756127 Type 111. Seems to be working fine expect that after the spin cycle the clothes are still pretty wet. Water is...
It sounds like what you're describing is a weak clutch. The clutch could be worn & slipping or may have oil residue on the clutch pads. I would recommend replacing the clutch. Here is a link to the part.
Jan 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
No Spin Cycle in Kenmore 80 Series Top Loading Washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
We have a Whirlpool,Type 111
you have a bad drain pump
May 18, 2009 | Washing Machines
Washing Machines Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal De
