Question about Dell OptiPlex GX270 PC Desktop
Heat sink glued to cpu on GX270
I have a new motherboard and would like to install the cpu from my old board. The cpu is however glued to the heatsink and I can't get the cpu off of the heat sink. I don't want to install the cpu with the heatsink attached because I may damage the cpu.
  • 232 Answers
If u say this unit is a dell , well u have to deal with dell or a expirence pc technician. dell is not fond of people working on there units so there system is made with there repair and manufacturing process in mind. its probably better to send the unit back to dell and pay them for the replacement. trying this yourself u risk damaging the system as a whole. remember the cpu is the heart of the computer.
Posted on Aug 04, 2008
    Problem Solver:
  • 11 Answers
You can use a straight-edged razor to remove the CPU without actually hurting the CPU. I would also make sure to clean of any dried thermal compound residue to avoid making the CPU absorb more heat on your new board. Just make sure that when you do remove the heatsink from the CPU, you are extra careful to not bend any of the CPU pins.
And when you place the CPU in the new board, remeber to apply a thick coat of thermal compound to ensure that the CPU remains cool.
Just take the laptop apart and install the new board. Be sure to remove components you need from the old board such as the cpu, memory, heat sink, etc if they are not on the new board. Also remember to apply a fresh coat of Thermal Paste around the cpu and heat sink.
May 30, 2012 | ASUS Eee PC 701 Notebook
My pc mobo is intel 915gav. processor is P4 pinless running with 1 gb 400 bus ram..after a new installation of win xp i worked hours continously..but in in next morning when i turn on pc after running
There will be a thermally conductive paste [Heat sink compount], a white tooth paste like substance, must be applied between the heatsink and the CPU. It is a must. If you have replaced, or unlocked the heat sink metal, and haven't applied this thermally conductive paste, proper heat transfer from CPU and the metal heatsink will take place, and the CPU will overheat, and finally go out.
Music videos are large files, which apply a great load to CPU, as processing video is a great task for CPU. Temperature must be below 40 degree centegreade, at any instant.
Just unlock the heatsink lock, take out the CPU heat sink out, and apply some heatsink compound [silicon grease] and retry. If you hear a beep sound after 3 seconds or so, after swithch ON the system, you have won. OK.
Feb 22, 2012 | Intel D915GAV Motherboard
I put a new power supply & heatsink with fan in my system & now I can't get it to power on. The heat sink was VERY hard to get on. I even put the old power supply back in & it won't power on....
If your CPU is sticked on the heat sink due to heat sink cement, could have damaged your CPU pins. Those CPUs like AMD and IBM Desktops we need to unassembled the same by tilting method. If your CPU pins are damaged, remove your CPU from heat sink by the help of a chisel type screw driver and clean both faces of heat sink and CPU. Do not scratch, use isopropyl alcohol to remove heat sink cement. Inspect any pins are dented or damaged. Align pins, if broken solder with help of a goldsmith. Reinsert the CPU in motherboard socket, apply a little portion heat sink cement in cpu face and re fix heat sink and recheck the motherboard.
Feb 12, 2011 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Have an Abit IS-10 motherboard and do not have video after replacing the heatsink and adding a newer HD running Xp-Pro SP3. How do I re-install the video driver as reccomended when I can't view anything...
I'm not sure what heatsink you are talking about. Changing the heatsink on a CPU does not affect the video, nor does adding a hard drive.
Now if you pulled out the old hard drive and replaced it with a hard drive on which XP Pro was installed, you need display drivers--but when you first start up the computer, display drives are generic and you can see the BIOS screen and you can also start Windows in safe mode.
If you have no video at all, even on startup, then you do, indeed have a problem. It could be with the monitor or it could be because you replaced the heat sink and did not seat the new one correctly or use heat sink compound. If this is the case, you probably just fried your
CPU and will have to replace it.
Aug 04, 2010 | Computers & Internet
Cpu heat sink working in three legs
Mar 28, 2010 | Office Equipment & Supplies
Amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
Pc shuts down ,reason cpu overheating
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
Jul 25, 2009 | Computers & Internet
Buzzer sound from motherboard spkr
Hi kuldeep11203, your Intel D101GGC board uses the Award bios.
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
Good luck kuldeep11203!
Nov 21, 2008 | Intel D101GGC Motherboard
Replace heatsink fan on CPU.
The thermal paste should be cleaned off. Clean the CPU and heatsink fan with a dry cloth, which should remove the paste quite well. It is simply a viscous liquid and should not require scraping.
You should replace the thermal paste when installing the new fan. You can purchase it at your local computer supply store. Simply place a small dab of it on top of the CPU and then install the fan.
If you try to re-use the existing thermal paste, you will not get reliable heat transfer from the CPU to the fins.
Sep 11, 2008 | Computers & Internet
Reinstalling a pentium 4 1.7ghz onto motherboard
donot attempt to install cpu with heatsink attached, detach and install.
Dec 13, 2007 | Computers & Internet
Dell OptiPlex GX270 PC Desktop Logo
770 people viewed this question
Alun Cox
