Question about Refrigerators
Our refrigerator is only about six years old. The problem began after the refrigerator was unplugged for about six weeks and then plugged back in. The freezer side works just fine. The refrigerator side will work for a while and then it stops cooling. If the temperature control is turned to zero and then back to the proper setting, it cools again (but stops again). Is this a repairable problem or should we be replacing?
  • 57 Answers
Maybe corrosion in the cold control. Could be a fan shutting down. When fresh food side is warming up , is fan running in freezer? My guess with the information given. A simple repair.
Posted on Mar 28, 2011
How do I unplug a drain if I do not have an air gap
Is it a plugged problem or is the drain solenoid maybe not working. Do you hear a click when it reaches drain cycle. If not the drain valve or wiring or possibly even the timer is defective. VERY seldom that a drain hose would plug up. Make sue the hose is not kinked also. You may have plugged house plumbing under the sink or etc also.
Sep 12, 2014 | Dishwashers
Maytag refrigerator
I think the fan is not working ( inside the refrigerator, not at the back)
Mar 10, 2013 | Refrigerators
My lg just died (only 1 year old) I unplugged and plugged it back in a got nothing... Is there a reset button?
hi there,
you can reset the error code by unplugging the unit and plugging it back in. if it doesn't work, call LG's customer service and have them send someone over.
May 21, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
FREEZER WORKS...FRIDGE DOESN'T
Hi,...
In that case you need to check this
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GSS20DBMB GE side by side refrigerator
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
hope this helped. Good luck
May 20, 2008 | GE GSS25SGMBS Side by Side Refrigerator
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
