Question about Black & Decker DF200 FryMate Fryer
Basket handle release broken. Cannot locate part
    Genius:
  • 1,739 Answers
Available replacement parts for the Black & Decker DF251 are available here:
http://www.directpartsandproducts.com/black-decker-deep-fryers-c-1_359.html
Suggest you contact the supplier at 800-738-0245 or by webmail at:
http://www.directpartsandproducts.com/contact_us.php to inquire whether the parts for the DF251 are compatible with the DF200.
Posted on Mar 29, 2011
Broken handle release pedal
Definitely. Just find your local authorized BEAM dealer and they will sort it for you. Sorry, I don't know where you are so I can't find you a dealer but BEAM's website has a dealer locator.
Dec 24, 2013 | Beam Q power Brush Q100
Electrolux side by side freezer baskets remove how
Hello augustus_ eli - To remove the top and/or bottom basket, pull the basket(s) out until it stops. Then, lift up on the handle and pull out at the same time to completely remove the basket. To reinstall top and/or bottom basket, align the basket with the rails and push in. The middle basket is held in place by four retainer clips; two on each rail. Before removing the basket, note the location of each retainer clip. To remove the baskets from the retainer clips grasps the handle firmly and pull up. The basket should release from the retainer clips. To reinstalled the basket place the basket on top of the retainer clips and press down.
Nov 27, 2012 | Electrolux EI26SS55GS Stainless Steel ...
I have a Phoenix AEG juicer with no instruction manual. Idon't know how to get the grinder basket out to clean it. There is no release lever. kdw
I have an old Phoenix AEG juicer - don't know if it's the same as yours. My basket is two-part. The flat bottom part with the grinder teeth holds in the strainer part, and has small holes at twelve o'clock and six o'clock. There is a clear plastic "wrench" which consists of a circular plate with a perpendicular ridge on top serving as a handle, and two pins on the bottom that fit in the two holes. You then unscrew the flat bottom part of the basket which releases the remaining strainer basket part. If you're missing the wrench you might be able to improvise.
Dec 04, 2010 | Kitchen Appliances - Others
The spin cycle does not work. The drum does not turn. The water drains out but doesn't go into the spin cycle to get rid of access water
sounds like a problem with your basket drive assembly brake release arm could be broken not releasing the brake allowing the basket to spin,,,,,
Mar 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
On Pulling Release handle in drivers footwell. No resistence is felt. suspected broken cable. Require a method of releasing bonnet catch or gaining access to cable locations .
REMOVED PANEL FROM UNDER THE BUMPER AND REACHED UP TO THE TOP OF BONNET AND LOCATED CABLE. PULLED ON CABLE WHILST 3RD PARTY PULLED BONNET LEVER IN DRIVERS FOOTWELL. BONNET RELEASED.
Jan 08, 2010 | 2003 BMW 7 Series
Frezzer basket handle broke
I boughta new handles
Dec 30, 2009 | Fisher Freezers
Does any one know how to open the hood on a 1987 300e if the latch doesn't release
There is a release cable that is attatched to the red releas handle on the drivers under dash panel. You can grab that cable with needle nose pliers to release the hood to the first detent if the handle or cable is broken. There is a secondary release mechanism(called a hood tongue) which routes through the grille where the rectangular slot is once the hood is popped up with the release handle.you can grab the rest of the broken hood tongue with needle nose pliers and pull it out to completly release the hood from the saftey catch. If it is completely broken you can take a long screw driver and push the saftey catch( i beleive to the right) and the hood should be able to open all the way up. Both the hood tongue and the cable(securing portion at release handle) are common failures and break over the years.if it is at the release handle you are having a problem-get a #2 phillips screw driver and remove the release handle to gain access to the loose cable. I hope I have been helpful
Oct 07, 2009 | 1990 Mercedes-Benz 300 Diesel
How to fold peg perego 2008 Pliko P3
You also have to pull on the middle part by the basket it has like a handle.
Oct 02, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Cant find hood release handle for my 1997 saab 900s conv. manual shows it should be located under instrument panel on left. its not there
the handle may be broken check for a cable with a small shinny ball on the end ...if it is there you will need a new handle or you can open it with a pair of pliers
Mar 10, 2009 | 1997 Saab 900
Broken Handle Release Pedal
what is part number for broken pedal release
Oct 29, 2007 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Black & Decker DF200 FryMate Fryer Logo
277 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
