Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Kitchen Faucet 470 WH installed by a plumber new in July 2007 is dripping continuously. How do I fix this?
  • 43,501 Answers
You need to replace the springs and seats...
Here is the kit you need...
http://www.bing.com/shopping/faucet-delta-parts-rp4993/where-to-buy/1C8A5B4DF3AE2B6FBEE4?q=delta+faucet+kit&FORM=HURE
Take the handle off.. there is a set screw under the handle...
Then turn the top off...
Take out the ball... observe the position of it...
Then use a very small screw driver to remove the old springs and seats and install new ones...
then replace the ball, top and handle...
heatman101
Posted on Mar 28, 2011
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
Mar 02, 2014 | Delta Faucet Plumbing
Faucet won't stop dripping
you can fix it yourself by replacing the o-rings in the cartridges inside the handles. if its washers, replace those and the seats located inside the faucet handles. depending on how old your faucet is, the replacement parts may be more than if you replace the entire faucet.
Nov 15, 2013 | Home
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
Faucet installed 9/94 and still looks like new. But in past few days have begun seeing slow drip running down from one of the inner metal flexible hoses when faucet is on and for maybe 5-10 min after water...
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
Jan 18, 2010 | Kohler K-12176-PB Fairfax Single Handle...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
62 people viewed this question
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
