Question about Garden
Coil gap setting mccolough mac 6 - Garden
  • 2,239 Answers
The air gap shhould be 0.3mm
Posted on Mar 28, 2011
I changed spark plugs on my 01 jeep grand cherokee it was running but turned off on me now it wont start anymore.
which engine?
2001 WJ , jeep.
wrong spark plugs!
gapped wrong!
wrong wire order?
do tell engine you have there.
do tell park plug brand and numbers.
do tell if engine has coil packs, how many, and how you wired them back..
now answering for USA cars, (not exports. or those jeeps made in Europe. )
the 4.0L engine with the 3 coil rack pack? with 6 spark wire sets?
the 4.7liter has 6 coil packs coil over plug COPS.
that can not be wired wrong but could be unplugged in primary side.
my guess, wrong parts, wrong gap
or not reconnected right.
if spark is lost, scan the PCM cranking, look for DTCs/
Dec 24, 2015 | Jeep Cars & Trucks
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
I have a mini mac six and need to know coil air gap
the easiest way to set that is to use a business card or book of matches
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 30, 2013 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How complicated is it to change spark plugs
Hello
It depends.Some autos need to have the front tire removed to get to the plugs.Or the battery is in the way.
Lets say you have a clear view at the plugs.
1. Tools You need a 3/8 ratchet with an 6 inch extension and a 5/8 or 13/16 socket.
2.A blanket or towell to cover up your fender so you dont scratch the paint.
3.A spark plug gap tool.Plug type and gap should be listed on the engine sticker under the hood.
4.Optional-undo positive cable on battery.
5.Start on first plug.DO ONE AT A TIME.pull 1 plug wire off ,and remove spark plug using your ratchet and socket.Set gap on new plug and install into plug hole.
6 Pull one wire and plug at a time so you do not cross wires and mess up firing order.
May sound like alot but its really easy.
Apr 23, 2010 | 2000 Ford Expedition
I have a McCullough Mini Mac 6 chain saw. THe spark plug is a Champion DJ-8. What should the gap be and what is a good brand of plug?
0.020" is a good gap setting for magneto type ignitions. Champion is the original plug and they seem to work well. If the plug is clean, it should have a snappy, blue spark when observed out of the engine. Hope this helps!
Apr 09, 2010 | Garden
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
1937 Zephyer ( ford v-8 flathead)
1. points not opening or closing
2. Bad condenser
3 bad rotor or cap
4. Bad coil
5. Not likely but could be just a bad wire from the switch to the coil.
First you need to know if you have voltage to the coil -- if yes- go to 6.
if no -- go to 7 ..
6. Put a piece of thick paper between the points contacts, then check for voltage at the points from the coil . If there is voltage at the points ,, check the gap with the points wiper set on the high side of the lobe on the cam in the distributor . A gap of .015-.018 is most common on that engine.
7. If no voltage then back track to the ignition switch ,, fuse box , then battery
I put a plug wire in the coil output to the distributor and a plug in the other end -- lay plug on block and crank engine .. If there is spark at the plug , your in the ball game . If the spark is orange change capacitor if blue spark good to go . you might want to clean and gap your plugs before you reinstall them .
Aug 16, 2009 | 1991 Plymouth Colt
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
