Question about Symphonic Televison & Video
Recently the audio in my televsion stopped working. The picture is perfect, but all of a sudden no sound when I turned the tv on. I've unplugged it and plugged it up again and still no sound. It is a 32" Symphonic television that I purchased at Walmart 4 years ago.
    President:
  • 1,140 Answers
Hello -
If you are using a cable/satellite receiver or digital converter, I would suggest resetting the receiver/converter. Some can be reset by simply switching off and on, some have a reset button and others need to be disconnected from the power supply for a minute or so. Reset the box, then try the TV again. Sometimes the software/firmware in these boxes can "crash" and "re-booting" the box will solve the problem.
If you have a DVD/VCR or game system connected to the TV, you should also test whether have audio on the TV from any of these devices. Finally, if the TV has a headphone socket, try plugging in a set of headphones to check for audio. You may have accidentally switched the TV speaker off.
If you've done all of the above and you have no audio from any device or headphones, it's likely that the Main/AV board (motherboard) in the TV has failed and will need to be repaired or replaced.
Please try the suggestions above, then post back with the results for further assistance. Please include the model number of your TV. If you don't know the model number, this can usually be found on a label on the rear of the TV. You can reply to me by clicking on "Add a Comment" below your question.
Hope this helps - good luck!
Regards,
BElectric
Posted on Mar 28, 2011
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
I have a insignia ns-lcd37-09 tv.The screen suddenly turned green.I can here sound but no picture.can you help?
Change input device to some other which you know works for sure. If problem persists, try changing the channel. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Insignia NS-LCD37 37 in. LCD TV
I dont get the sound, can see pictures.
hey sajith,
check all the audio and video cable's connected to tv and dvd player.
you may have forgot the wire color's (audio and video) there would be one wire for video and two for audio. some times there would be a RF socket also. so, see the right sockets and connect to tv by interchanging wires.
Dec 29, 2009 | Sony DVP-NS575P DVD Player
Sound but no picture, tv turns off and on
It sounds Lamp is dead in your TV, how old is this TV and did you replaced its lamp recently?
Click Part Store to see required lamp image and price info.
Nov 02, 2009 | Toshiba 46HM95 46" HDTV
Sound doesn't work on Toshiba 36"
Unplugged the TV for 5 minutes and the audio is working now . . . what a pain to have to do this with how complicated theater systems are today!
Sep 02, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Perfect picture but the sound is just static!
There is either a tuner problem or trouble in the set's sound processing. When you send audio in through the rear panel jacks, you bypass the circuitry that extracts the sound from a broadcast signal. It's impossible to suggest a place to start looking for you to try repairing it on your own. Depending on how large a set this is and its age, you might try calling for service and get an estimate, or use this as an excuse to replace the TV.
Dec 12, 2008 | Televison & Video
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Nov 17, 2006 | Akai LCT2060 Television
Televison & Video Logo
26 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
