Question about Canon PIXMA iP1600 Printer
Waste ink absorber
This is almost full. What do I do?
  • 2 more comments
  • watercolor Aug 04, 2008
    The solution I got did not work. Waste Ink Absorber posting "almost full"
    waste ink absorber posint "almost full"
  • kati_phusio Aug 27, 2008
    I have message appear after each print jb, "waste Ink absorber full" what do I do??? I press the resume button as told and all looks ok but it keeps repeating after each print job. Steps taken are to look in the internet for solutions, and phoned supplier
  • raveluz Mar 16, 2009
    i had the same problem with my pixma ip1800.
  • 3 Answers
REMOVE COVER AND THE SCREW ON THE ON THE INK CARTAGE HOLDER AND THE SILVER BAR AND THE INK CARTAGE HOLDER COME OUT. CLEAN THE AREA BELOW IT CANT MISS IT NOW GETTING BACK IN IS THE HARD PART.
Posted on Mar 17, 2009
    Genius:
  • 1,011 Answers
Follow these steps and hopefully u will get rid of this.
is it really full or just giving the msg.
by the way do this.
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
it should help u. if not then tell me .
regards,
Posted on Aug 04, 2008
  • Canon Master
  • 19,396 Answers
"Canons generally have four screws that hold the entire printermechanism on the plastic base. Some models do have a power supplymodule that slides out of the rear of the case, remove this first.Remove the four screws holding the printer mechanism onto the lowercase. Some models may have more screws, but becareful not to remove anyother screws! It just lifts off.
Take the waste ink pads out and lay them down on some newspapers by thesink. Set the waste ink pads in the sink. Pour some of the cleaningmixture into them to dissolve the ink, then gently run hot waterthrough to rinse it out. It will never look clean, don't try, just getit so there is little ink left in the wash water. It is a ratherfragile felt-like substance so if you try too hard, you can end updestroying it.
Squeeze out as much water as you can. Do -not- twist it like a towel!
Reinstall the ink pads and reassemble your printer.
Once you've got the pad cleaned and the printer back together, you'll need to reset the counter or it won't print.
2. unplug AC power
4. press resume 4 times"
From Where is the ink waste absorber
  • Ginko
    Ginko Aug 04, 2008
    There are two possibilities,
    1 The absorber is not full but the printer returns error because of the number of prints in counter, Then printer reset if you do this
    2. unplug AC power
    2 The absorber, that is a sponge is really full, and if you keep using printer ink will leak out, in this case take the printer at a repair shop or do it yourself following description above.
    This is the solution, like it or not.
  • Ginko
    Ginko Aug 04, 2008
    My suggestion: do the reset procedure a couple of times, if it does not work the absorber must be replaced. This is a dirty job, it leaks a lot of ink and you have to take apart the printer. Ask at a local repair shop a quote for changing the absorber.
  • Canon Master
  • 6,487 Answers
Try this:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The
indicator should be orange.
6: Press Power to set data.
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 04, 2008
    Open printer with gloves or unless you don't mind getting your hands dirty, Open top of printer lid carefully pull out spongey grey piece at bottom of printer to your left side is a piece of plastic, pull that off and below it is another sponge.
    Carefully pull this out as well. Wash and squeeze excess water. replace.
    YOU MAY WANT TO USE A FLASHLIGHT TO BE SURE YOU CAN SEE WHAT YOU ARE DOING. Unplug printer, hold button. restart, release button as described above. Keep trying. Then do a bottom plate cleaning. keep trying eventually everything resets and you can continue working. To remove ink from hands and plastic, use alcohol.
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Absorber tank is full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 01, 2009 | Canon Office Equipment & Supplies
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
canon mm140 E27 = Waste ink absorber full or platen waste ink absorber full what would be made to solve this problem
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
226 people viewed this question
old marine
old marine
Corne Viljoen
