Question about Centrios Wrist Strap Blood Pressure Monitor
Gives wrong pressure readings. also shows only error on pulse. can be repaired or buy new one. if fixable where to send to
    Brigadier General:
  • 4,736 Answers
You didn't mention how long you've had this wrist monitor, but it may be a case of it not being used properly. For it to work best, you need to keep your arm/wrist still at heart level. Place the cuff on your wrist, at least 1" above the heel of your hand. Be sure the strap is fitted snugly ground the wrist before starting the unit. Then remain still. Don't flex or shake your wrist during the testing procedure. You may also need to change the batteries.
If none of the above solves the problem, most BP wrist monitors have a 5 year limited warranty (check your Owners Manual for yours) and will allow you to return to them for repair or re-calibration. But you must have their approval before sending it, as well as your Proof of Purchase.
Hope this helps you to solve the problem.
Posted on Mar 28, 2011
Ford aerostar troubleshooting
It could be any number of things, most likely cause is you have a oil sending unit that is wore out and giving false readings. Either buy a new sending unit and change it out or hook an oil pressure tester to your engine and check the oil pressure.
I'd buy a new sensor and replace it myself, because the vehicle is 23 years old and probably the original sending unit, besides the oil sending unit has to be removed in order to check pressure with mechanical gauge anyway.
Sep 20, 2017 | 1994 Ford Aerostar Extended
The error "en1" , pump
the pump is giving a EN1 Code. What does that mean
Jan 19, 2011 | Comfort Line Spa 2 Go Portable Spa with...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Only red dot is blinking not complete line
Hello har digi. I wish I had better news for you, but if your scanner only shows a dot and not a line, it means that something has gone wrong with the scan engine. This is fixable, however you'll probably end up spending as much getting it repaired as you would buying a whole new scanner. If you'd like to send me a message or email, I'd be happy to recommend some scanners that would work just like the one you're using and have a low price-point. I hope this helps. Good luck!
Dec 24, 2009 | Metrologic Instruments MS5145 Handheld
Factory oil pressure gauge maxed out at 80psi and shakes
is oil level full? oil sending unit will either be near filter or near distributor buy one look both places replace if no change get live oil pressure reading if shows better or lower than guage has short at censor in dash giving false high readings
Apr 05, 2009 | 1992 Chevrolet S-10
My wii wont read disc
This is a hardware failure. Sending it Nintendo is the only option. Unless you think you have the skills to repair it yourself. Here is the link to Nintendo
http://www.nintendo.com/consumer/repair/repair_options.jsp
Dec 08, 2008 | Nintendo Wii Console
Wii will not read the disc.
You'll have to send it to Nintendo to be repaired. Or you can buy a new Wii. (It'll probably cost as much to repair as replace.)
Whether this problem was caused by modifying the Wii or not is hard to say. It's probably just a broken DVD reader. In the future I suggest NOT modifying your consoles as this breaks the warranty.
Nov 29, 2008 | Nintendo Wii Console
High engine oil presure
Hi, I had the same problem, same vehicle (same year), same engine. I bought an oil pressure tester at Harbor freight tools for $ 8. I was trying to figure out, if the pressure is really high, or just the sending unit is defective. The tester after connecting it to my engine was reading correct pressure for this vehicle ( between 25-30 PSI when idelling), which showed that the oil pressure sending unit is defective. At Advanced autopart store they want about $ 47 for the sending unit, so I put the defective one back in place (still reading H). I'm planning to replace it after next pay check :o) Good luck. Pavel**
Oct 11, 2008 | 2002 Jeep Grand Cherokee
Motor pulsates in rapid sucsession little pressure,with lance removed continuesto run normal,new lance same problem,my estimation is the valve at fault that controls the pressure switch
It could be the pressure switch itself at fault. If it is reading (in error) too much pressure, it will shut off for a second and then pulse as you say.
If the pump seals have gone, you may get this effect too. Depends if the pump is being controlled wrongly, or just malfunctioning itself.
Jun 18, 2008 | Washing Machines
Unable to read disk
There is something wrong with your laser. You should be covered under warranty, send it in for exchange or repair. Here is the Nintendo Repair Center Help Line: 1-800-255-3700
Jan 19, 2008 | Nintendo Wii Console
Centrios Wrist Strap Blood Pressure Monitor Logo
165 people viewed this question
Top Centrios Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Centrios Health and Beauty Expert? Answer questions, earn points and help others
