Question about Brother Sewing Machines
The speed controller no longer controls the speed on my brother se. It now changes the needle positon can it be fixed?
    New Friend:
  • 194 Answers
Go into the tools menu and set it to control the speed
Posted on Mar 29, 2011
I was given a brother cs-8150. The manual says it will operate without foot feed. I tried to use auto sew and machine tells me to change speed controller mode to off. Where do I do that.
Not able to find any online instructions for your machine, so here goes. There may be some confusion as to what foot feed means.
I believe foot feed refers to the feed dogs. When you disable the feed dogs (drop them), then you must manipulate the fabric manually--used mostly for darning or free motion quilting. In essence the feed dogs are no longer moving the fabric for you. Instead, you manually move the fabric and control the speed at which it stitches with your foot control. Perhaps that is why you need to turn off the speed control because you will determine the speed with your foot.
Foot control refers to the foot pedal that you use to control the speed that the machine sews (much like the gas pedal in your car). Some machines have the ability to sew without the use of a foot control unit. To do so, there is usually a button or lever somewhere to start and stop the machine. When activated, the machine will continue to stitch until you stop it.
Hopefully this will help you find a resolution.
Mar 28, 2016 | Brother Sewing Machines
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
Brother se 400
try changing needles
also possible that the machine is out of time
Apr 09, 2012 | Brother SE400 Computerized Sewing Machine
After interference, the needle won't reposition left or right properly.
sounds like something got damaged or broke & the machine needs to be checked
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Jul 22, 2009 | Brother SE-270D Computerized Sewing...
Fo4--What does it mean and where do I find the translations?
F04 is foot control error. It is probably a bad foot control, but it may be the plug in on the machine or a circuit board.
You can run the machine without a foot control for now; just unplug the foot control from the machine and use the Start/Stop button like you would when embroidering.
Before replacing the foot control, you should bring the machine to a Brother shop and try a new control. If the new one works, then the control was the problem.
Aug 03, 2008 | Brother SE-270D Computerized Sewing...
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
209 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
