Question about Altec Lansing ADA745 4 Speakers
Buy system - Altec Lansing ADA745 4 Speakers
Looking to buy a "6CD stereo shelf system 500 Watts?
Consider first a separate system. For if one part of the shelf system fails you have to buy everything. If the CD say on a separate system fails you buy just one CD player. Separate systems have also much better sound quality also.
Oct 11, 2015 | Audio Players & Recorders
CDBA3100 Hi, I found this part for $15 and for $6.50-One picture shows the loop not the wires that connect , my question is-can u buy this part without the wires? Any help would be appreciated.
Not sure of the question, but for $21.50 why not just buy both? or
buy the $6.50 without the wires and use your old wires or
buy the $15 with new wires which would probably be what I would choose.
Sep 08, 2015 | Sharp CDBA3100 Remanufactured Mini-System...
Microsoft - buy new product key
Windows non OEM editions can only be installed I believe 25 times before you must buy a new key. OEM edition can be only on the system that it was registered to. So if you are installing an OEM version on a system other than the one the key was registered, you need to buy a new key, or better yet upgrade to windows 7.
If you installed it more than I think 25 times to a different system or on the same system, than you need to buy a key, or better yet upgrade to Windows 7.
Windows XP is no longer supported by Microsoft. It is in your best interest to upgrade to Windows 7.
May 17, 2014 | Microsoft Windows XP Professional for PC
Donsent goes fast
Depending on how long it's been since you installed the OS the performance of the OS lowers. It gradually slows down.
You could backup your data and do a fresh install of the OS.
An OS can be only as fast as the system. So one option is to buy a better PC.
Buying a whole PC can be expensive. A cheaper alternative would be to buy a Solid State Drive (SSD) and install the OS on it. SSD will make it seem like your computer is now 3 times faster than before.
There could be virus involvement in the system. if you dont want to buy a new system or do a fresh install then you should first scan your system for any viruses, malware, spyware, adware, bloatware etc. removing these application is wondrous for the system.
Hope this helps.
Jan 24, 2014 | Computers & Internet
I currently have 2 x 1GB 667mhz ram in the yellow slot and I am thinking of buying 2 x 2GB ram but do I have to get the same Mhz or am I able to get a higher speed.
You have to buy the right "family" of ram. Your system needs DDR2.
You can buy any DDR2 and it will fit into your motherboard but your system specs are for DDR2 800 (also called PC2 6400)
You could buy 1066 (PC2 8500), which is faster, but it will run @ 800 instead of 1066 because your system is rated at 800.
So buy whichever is cheaper. Try to buy them in sets (matched pairs - 2 sticks of ram in same package).
Buy memory with good reviews (and prices) check newegg.com
Feb 16, 2010 | ASUS M2V Motherboard
Lost the cable that connect from the system to the subwoofer
any electronics store,Radio Shack,Best Buy, Circuit City... they should have a good selection, if you got a best buy - its more recommended they have Whole selection on Home theater systems.
Oct 16, 2008 | JVC TH-C5 System
I lost my remote. Where can i get a new one
go to remotes.com they have all remotes for everything but the remotes for durabrand products cost just about as much as the system itself so its easier just to buy a new system
Nov 24, 2007 | Panasonic sa-ht800V Home Theater Audio...
Lan card
Yes you can buy the cards separately without having to buy a whole new system. Try PC World but eBay is a good place to start
Nov 20, 2007 | Sony PlayStation Portable (PSP) Console
Altec Lansing ADA745 4 Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
