Question about NEC VT695 LCD Projector
My plastic lamp cover broke...I need to purchase another. I need the part number and a vendor that would carry the cover for a NEC VT695
3 Suggested Answers
  • 13433 Answers
SOURCE: is there anyway that i
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Posted on Sep 20, 2010
sodeep
  • 3267 Answers
SOURCE: I want to connect my
you need this ----------- Apple MC552ZM/A Video Cable Adapter HD-15 Video - Male Proprietary
Posted on Jun 17, 2011
HOW DO I RESET LAMP HOURS FILTER HOURS AND RETURN THIS PRODUCT TO FACTORY SETTINGS
For the lamp all you need to do is navigate the menu. This option is always somewhere different in different manufacturers but it should be in somewhere like options or settings. Once you find it you can to a lamp reset back to zero hours.
Nov 11, 2015 | NEC VT695 LCD Projector
Why does status light flash red on VT695 proxima?
Usually it's a warning that the lamp is either close to it's end of life or it has expired.
Sep 08, 2014 | NEC VT695 LCD Projector
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
Having a problem getting past the red blinking status and orange blinking when trying to start up a NEC VT595 projector. This is after installing a new bulb.
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
Jul 13, 2011 | NEC VT595 LCD Projector
I want to connect my iPad 2 to the NEC video projector VT695. do I need a VGA or an AV adaptor?
Jun 17, 2011 | NEC VT695 LCD Projector
When power button is turned on it has a orange light and the lamp button is red. It is not the bulb because it worked in another projector of the same kind.
The bulb is not lighting.
Make sure the covers are going on correctly if I remember this one has an inner cover as well.
There is a little micro switch that needs to be operated by cover going on correctly.
also check the plugs / connectors are ok.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | NEC VT695 LCD Projector
Staus light is blinking red, it has a new light and filters, what next
If it is blinking once every 4 seconds or so then the cover that goes over the lamp is either missing, open or broken. It will not look broken but a critical part of the plastic has probably broken off. This will happen even if the cover has not been touched. Without it the projector thinks the cover is missing or open. Try another cover if you have one to be sure.
Oct 19, 2010 | NEC VT695 LCD Projector
I just replaced the lamp. Is there a reset proceedure for the lamp light?
No reset other then resetting the hours in the projector's menu. This is for reference only and will not keep the projector from coming on. If the lamp will not light make sure the lamp cover is all the way on and nothing has broken off of it.
Sep 28, 2010 | NEC VT695 LCD Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC VT695 LCD Projector Logo
336 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
