I hav a Grundig "Mandello"
  • 1 more comment
  • bandb319 Mar 29, 2011
    If it was that simple I would have fixed it 10 years ago. It is not a strap. There is a rectangular strip about 1/2in by 1/8 in and about 9 1/2 in long. The upper end has a stop. As the door closes the strip slides thru the upper mount.
    d32ab
  • bandb319 Mar 31, 2011
    No help at all. Apparently you can't help at all. Why don't you refund my money and i'll call it quits.
    d32ab
  • bandb319 Apr 02, 2011
    Both.
    d32ab
    Brigadier General:
  • 4,736 Answers
Here is a link to a website that list over a dozen sources for antique radio parts and cabinets. There's a good chance one of these listing can help you. http://www.grillecloth.com/other/parts.php
Apparently, there's a big market antique radio restoration. Good luck, I hope you find the part(s) you need.
Posted on Mar 29, 2011
  • Rich Landrum Apr 01, 2011
    Bill, which responder's solution are you referring too?
    Scholar:
  • 80 Answers
I just googled the image for your radio, I can see that the plastic "stops" look like straps to me, if they are simple plastic straps then you can replace it but you it will be difficult for you to find the exact same piece.
You can visit any antique furniture store in your local area with your broken stop. Show it to them and they should have a replacement. Also you can visit your local hardware store and ask the clerk for a replacement stop. They should be able to "jimmy" one up for you. Finding an authentic stop is not impossible but it will take time to find.
Once you have the stop you can choose to glue it back into place or screw it back on.
Hope this helps.
Thanks
Posted on Mar 28, 2011
Grundig radio code
For all Grundig radio codes from the serial number contact this link: Car radio codes in Uxbridge London Gumtree
Feb 02, 2017 | Grundig Audio Players & Recorders
My battery has been disconnected for 6 years. Car goes but radio just says code. I have tried to punch the code in but it just beeps and nothing happens. I have the correct code for the vehicle as hav
YOu have a blown fuse. The OEM radio has an error code and basic power supply that gives you an error response. Check your fuses and make sure that the main fuses and fuses for the radio and console unit are good. If it's an aftermarket unit it may be a bad cmos battery that needs to be replaced.
Jan 28, 2015 | BMW 1997 318i Radio a1z106995 CD changer...
How to open the battery case and how to replace the batteries for the Grundig Mini 300 WorldBand Receiver
Press down somewhat firmly on the battery cover and slide with your thumb downward...it should slide off....Just be careful not to snap or break the tabs that attach the battery door to the body of the radio. It's really very simple!!!
Dec 13, 2014 | Grundig Audio Players & Recorders
Need to know how to fix cd draw not closing or opening by itself. Repair places in Brisbane, Queensland Australia
Hello,the most common failure part on that model is simply the belt.Remove the cover,near the front on the bottom is the belt simply remove it and apply alchohol with a qtip to the inside of it to restore its grip. Also to first open the door on the bottom is a slot ,simply put screwdriver in there(while its unplugged )and slide the bar over this will free the door allowing belt access. After belt is cleaned be sure to close the door by hand before plugging it in so it can retime itself.
Dec 12, 2010 | Yamaha CDC600 5Disc CD Changer Player
Grundig radio code
The radio will have to be removed from the car  dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS  on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Mar 04, 2010 | Car Audio & Video
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
Unlock code for grundig car 200 radio cassette
reset code for grundig car200 casette radio
Sep 02, 2009 | Vehicle Parts & Accessories
How do you open c/d changer in trunk?
front of changer has a sliding door,slide open & below cd magazine is a small button,press this&magazine will eject,this will not work if changer is disconnected from the vehicle,
hope this helps
Jul 02, 2009 | Nakamichi Car Audio & Video
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
310 people viewed this question
 Grubhead
Grubhead
