Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old not that bad 125 hrs) . discovered fuel pump bad. replaced pump and now still does not start. checked plugs and have spark, and now fuel ??.
    Scholar:
  • 130 Answers
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Posted on Mar 28, 2011
Two years ago i purchased a Craftsman riding mower with a Briggs&Stratton 24 hp inteck v-twin, it ran fine the first season but that was it. Last year i tried to get it started by changing plugs and...
Gas is so poorly refined these days, Youll notice the fuel stabilizer says it is only good for about 30 days. although i cant give specific instructions on how to clean out the clogged jet in your carb, if it runs on starting fluid, a clogged jet is deffinately your problem. start with the float bowl make sure it has clean fuel in it and the primary jet is usually in the bolt that holds the bowl on make sure its clean and if the float hanging down opens the needle valve and fuel flows your good to that point. if the engine still wont run, or only runs with the choke on. get some carb cleaner spray and go at it, make sure you can blow through every port and jet, BUT WATCH YOUR EYES you never know where that stuff is going to exit.
next year winterize it, drain the fuel and run it till it dies.
or i like to winterize my engines by replacing the regular fuel with a little bit of aviation fuel as that stuff can sit for years, just dont operate or mow for more than 2 or 3 minutes on it.
Good luck
Apr 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Have a John Deere lawn tractor with 20HP Briggs V Twin. Engine ran great four 4 years (200hrs.) then started having fuel problem. Changed filter didn't help, changed fuel pump didn't help, cleaned...
You could try sending your question to the Customer service on the Briggs & Stratton Website. Maybe they will be able to explain and suggest a good solution.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a relatively new 16" Husqvarna chainsaw, and I have the hardest time getting it started....sometimes I can't even get it started. Once I get it going, it usually runs fine, but it is extremely...
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Stalls, with oil runing out the exhaust
you have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Jun 29, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
260 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
