Replacing red reset button on a Rudd Model UPMC 036JAZ air condiction untit.
5 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: I have Rudd Ultra Series Central Air and I'm
Hi, as far as this unit having a reset button on it, it would not. If this unit is a gas fired heater, it will have reset buttons on a couple of its safe controls such as the high limit switch, or roll out switch that sometimes will trip and will have to be reset. If the unit is not on in the cooling, you need to check to make sure the thermostat is calling and that there is voltage to both the indoor and outdoor units. Check the circuit breakers to see if maybe one has tripped. On the outdoor unit you will have a disconnect box mounted near the unit. It also will have 2 fuses inside of it. They may be hidden from view behind a panel cover, but you may have blown one. Your unit is a 3 1/2 ton system according to your model number in case you ever need to know. But yes, this is what you need to do if the unit stopped cooling, is to locate the breakers for both the indoor unit and outdoor unit to find if a breaker has tripped for some reason, such as it overloaded. If you do find one tripped, it will be in the midway position. Shut it off hard, and again back on hard to reset. Please keep me updated on what you have or have not found, so that I can walk you through getting it back on line.
Sincerely,
Shastalaker7
PS On the indoor unit, this model should have a 3 to 5 amp fuse on the main control board just behind one of its panels. It may have a inspection view hole you can see through to see if the led red light is on. If so, this will tell you if the indoor unit has power to it if the light is on.
Posted on Apr 09, 2010
SOURCE: Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Posted on Jun 19, 2010
wise_jf
  • 66 Answers
SOURCE: Is there a reset button in the outside unit of a
There is a red button between the copper lines. Yes, Virginia, there is a reset button.
Posted on Jul 24, 2010
  • 674 Answers
SOURCE: RUUD uaka-036jaz not cooling, outside fan does not
Check your disconnect or breaker that is located close to the outside unit. Next you need to check the contactor in the outside unit. Set the thermostat to make the air come on then check the contactor. It should be pulled in closing the contacts. If it isn't the problem could be the contactor or thermostat. Next check the voltage on the load side with it pulled in. If that's good then check the capacitor. If it looks swollen, it's bad. You can also use a multimeter with the capacitor check function to do this. Let me know what you find.
Posted on Sep 27, 2010
How do I locate the aux limit switch on a rudd urka gas furnace?
Been awhile since I worked on one, but here goes. Should be 2 rollout switches on burner assembly and another in blower housing. Most are resettableand have a red button to reset.
Nov 19, 2014 | Heating & Cooling
Where is the reset switch on a Rudd 13AJN air conditioner
It should be at the bottom of the condensing unit between the two refrigerant lines. Will be a red button
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_70df8fb57a5e233e
Jun 27, 2014 | Ruud Heating & Cooling
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Jun 18, 2010 | Ruud Central System Air Conditioner
Unit not turning on rudd model UAKA 024JAZ
Check float switch at Air Handler inside. Check breaker to outside unit. May have red button on outside unit by copper lines may be tripped. Have someone turn on unit while you stand by it. Can you here the contactor pull in. If so you have a high voltage problem. Call service tech adn ask for free estimate. That way you know what is going to cost you. Rus
Jun 27, 2009 | Ruud UBHC Air Conditioner
Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Jan 02, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
