Question about Canon PowerShot A520 Digital Camera
Yes, I have a Canon Powershot A520 4.0 Mega Pixels and the shutter cover only open 1/2 distance ... can I fix it so I don't have to use my finger nail to pop it all the way open
    Master:
  • Canon Master
  • 443 Answers
You may find if you take it to a camera place and get it fixed properley it may work better
Posted on Dec 25, 2011
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
My canon a6o intermittenly gives me smudgy display and pictures. Ia there any quick fix for should I bin it?
If it has low Mega Pixels it's worth binning if it has high take it to a camera shop to get it looked at. Good Mega Pixels 8 - 14 rubbish mega pixels 2 - 6. hope this helps!
Dec 18, 2010 | Canon PowerShot A75 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Its shutter is not opening
Dec 18, 2009 | Canon Cameras
Turn the power off and on again
Is it model with automatic cover of lens, like the DSC-T3 has? Problem is probably with lens cover. Try to move it (or help while it is trying to open/close) by your finger. It does sometimes if it is dirty (inside). I gues because you did not write the model name and number and on the picture is DSC-T1, but it has only 5.Mpix. If you have model with telescopic lens it is probably damaged gears of lens.
Sep 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Shutter Opens Partially
This is a common problem for the A520 (it happens on mine sometimes). Recommend trying only the simple fixes listed on the following web page, but do not recommend opening the front cover which is also listed here. The A520 is a little tricky getting back together.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
May 17, 2008 | Canon PowerShot A520 Digital Camera
Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Oct 18, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A520 Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
