Model code #2N46B610A5FXZA Type#LN46B610 Need 1 picture board
  • 11,361 Answers
What is the 'PICTURE BOARD"? What is the problem are you having?
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=LN46B610
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 28, 2011
REPAIRING A SAMSUNG LCD TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 11, 2015 | Samsung LN46B610 46 HDTVReady LCD TV
Lines appear on screen a a couple mins of being turned on
If you still have lines after replacing the capacitors there may be other bad components that need to be replaced
Jun 02, 2013 | Samsung LN46B610 46 HDTVReady LCD TV
When I turn on my rear projection tv & the tv is cold the color will float,the picture will shake side ways for about 15 minutes.what can I do to fix the proble?
You did not provide a model so I am not sure of the type of set u have. Wheather it be CRT, LCD, DLP or LED. My 1st guess regarding "color float" is possably the convergence board/section of your set. And the warming up issue could be the result of cold solder connections and/or faulty caps on 1 or more circuit boards. Search your model number through the internet for clues.
Dec 08, 2012 | Toshiba Televison & Video
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
I have a Whirlpool Cabrio dryer, model WED6400SW, that displays an F1 code. What type of problem does the F1 code signify?
F-1 means a power failure occurred unplug for 15 minutes,it may clear the code,if not you need to check all connection to and from the main control board for good clean connections then retry powering it up again,if this doesn't help then replace this control board
Mar 06, 2011 | Dryers
I HAVE A SONY KP-FW46M31 PROJECTION TV, LED BLINKS 10 TIMES WHEN SWITCHED ON THEN TV SHUTS DOWN. THERE IS SOUND BUT NO PICTURE?? CAN ANYONE PLEASE HELP WITH A SOLUTION. I HAVE HAD ALL BOARDS OUT AND DUSTED...
It could be your high voltage trippler that connects to FBT flyback Transfomer. Let me know if you need any more help. Mats has parts 1-800-628-1118
Try Partsore.com and Google to Encompass Parts Distribution and type in your model number,see if they have Free swervice Manual you can print out online.Also Type in your search bar Understanding Sony Blinking Codes
Jun 02, 2010 | Televison & Video
My dlp tv does not show a picture, you get voice but no picture, sometimes no pic and no voice, we can see our cable guide on the tv but no picture, all the other tvs work, this is our first mitsubishi and...
Mitsubishi has problems with alot of leaky and Bad capacitors on power supply board, you need to replace Lamp if TV is over 16 months old. Most Lamps only last for 5,000 playing hours.
Mats has them 1-800-628-1118
Encompass Parts Distrubtion also will list Parts /Prices for this TV just type in your model number. 1-800-638-3328
Mar 21, 2010 | Televison & Video
RE: mother board not going on
Hi marlonvig, what type of memory (PC3200? or PC2700) memory are you using? What type in which slot?
The decription (In you're manual), refering to you're memory can be confusing.
You're manual says you can use up to 1GB of
PC3200 DDR400MHz only in Slot 1.
If you add DDR400MHz into slot 2. The board will not support it. (weird)!
If you want to reach 2GB of memory. You must use PC2700 (DDR333)MHz. 2x1GB PC2700 = 1GB DIMMS in both DIMM 1 & 2. You're board does not support DDR2 type memory.
Need you're manual? Download it from this link. Click on it.
http://www.asrock.com/mb/manual.asp?Model=775VM800
Asrock's home page for you're 775VM800 board.
http://www.asrock.com/mb/overview.asp?Model=775VM800
Mike
Apr 28, 2008 | Asrock 775VM800 Motherboard
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
