Question about Electrolux Vacuums
Model C153C The vacuum cleaner starts but stops immediately. If I disconnect the hose it will run but if I partially put my hand over the suction it shuts off. Both filters have been changed.
    Brigadier General:
  • 3,513 Answers
Hi
If the vacuum cleaner works but then shuts off unexpectedly, it may be because of restricted airflow which can cause the vacuum cleaner to overheat and shutdown. Check the vacuum cleaner for clogs and if the bag/tank is full. Remove all clogs and change the bag or empty the tank. Another reason is poor or no suction .There could be a clog in the hose or the bag/tank may be full and need to be replaced or emptied. Also, check the belt to see if it is worn or broken; if it's defective replace it.
Given bellow are detailed articles to fix vacuum cleaner, if something goes wrong please go through the link to have an in-depth knowledge related to your issue:-
http://www.wikihow.com/Fix-a-Vacuum-Cleaner
http://books.google.co.in/books?id=MOIDAAAAMBAJ&pg=PA86&lpg=PA86&dq=vacuum+cleaner+runs+if+the+hose+is+disconnected&source=bl&ots=iWsmiUNYuA&sig=Wa_saem8YMSf83geT_rMoPcU3hI&hl=en&ei=PtOQTZSPB8GHcdnxvKQE&sa=X&oi=book_result&ct=result&resnum=2&ved=0CB4Q6AEwAQ#v=onepage&q=vacuum%20cleaner%20runs%20if%20the%20hose%20is%20disconnected&f=false
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 28, 2011
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
No suction on my dyson dc27
Most common cause of loss of suction are objects being lodged. You can isolate the area pretty simply. Put your hand to the tube on the detatchable handle. If there is suction there the obstruction is at the base. To clear this turn the vacuum over and lay it down. There is a suction hose that attaches just behind rotating sweeper. Disconect it, and check for debris. Also look in the sweeper compartment for hair, and other clogs. Re-Attach, to see if this remedied the problem.
If the loss of suction is somewhere in the detachable handle. What i have done is disconnect it from the unit... Take a wire hanger or similar and carefully run it through the hose. Be careful not to puncture the hose.
Jul 19, 2014 | Dyson DC27 Bagless Upright Vacuum
I have a Dyson DC07 and it has lost suction. I have checked the belt, cleaned the circular filter and emptied the dirt chamber. The hose still has plenty of suction but I can't use the hose the vacuum...
Here are some things you can check.First you need to see if the problem is with the suction or agitation.If the suction on the hose for using the attachments is low you either need new filters a new cyclone(they are not cleanable) or it is clogged.To check for a clogg remove the cyclone and turn on the vacuum cleaner.you can put your hand over the suction side of the handle tub and feel if it has suction there.Reinstall the cyclone and again check the hose.If it is the same you don't likley have a suction problem you have an agitation problem.The 2 belts on the DC07 are part of the clutch and when they are strectched to a certain point (3-5years) the clutch needs to be replaced.you can check the clutch by turning on the vacuum cleaner and applying slight pressure downward on the front of the vacuum head.If the vacuum makes a loud ratcheting noise or you can stop the brush from turning the problem is most likely the clutch.One last thing is to make sure the bottom plate is on correctly I often see a misaligned bottom plate and the brush dosen't hit the carpet so it dosen't pick up.  www.sewvac.com
Jan 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
No suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Apr 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lost suction from cleaning dyson roller brush
This is actually a very common problem that we see for repair on Dyson Vacuums. Usually what happens is that the vacuum doesn't loose suction like most people think. You can test this by feeling the suction power on the hose. If you have suction coming from here, then most likely the machine isn't clogged.
What happens is that the bottom soleplate on the vacuum cleaner can easily be re-installed the incorrect way. If this happens the brushes on the vacuum cleaner can not even hit the carpet, which makes the vacuum feel like it's not picking up, but when the suction is tested from the hose it has plenty.
We see a lot of Dysons come in for repair with this problem. The bottom plate is not flush with the rest of the vacuum cleaner. Here's a picture of what an improperly installed bottom soleplate looks like:
When the bottom plate is put back on the vacuum, you should make sure that the bottom plate (the purple colored part in the picture) is flush with the agitator housing tray (red part in the picture). If not, the brushes will not hit the carpeting, and the vacuum won't really pick up anything.
This is how a correctly installed bottom soleplate should look like:
This should be the first thing you should check on your vacuum cleaner as it's the easiest and most common solution. If this doesn't fix your Dyson, please just use the Clarification Request form, and let me know which exact Dyson model you have, and whether the vacuum has suction power from the hose, whether the brushes turn when set to the carpet setting, and how old the vacuum is. I'd be happy to try and further diagnosis the problem with you.
I hope that this was helpful to you. If it helped you, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner.
Thank you very much,
Chris J.
GoVacuum
Mar 31, 2010 | Vacuums
No suction
well, it actually sounds like there is a blockage. Try removing your hose and dropping something through it, like a quqrter. If it comes through, no clog. If it is clogged, I believe that machine has a blower on the upper part of the cleaner (maybe in the bag compartment towards the top. You can take out the filter holder and plug the hose in there and run the unit . Does the blockage come out? If not, Try shaking the hose, or you can put a stiff wire in it to try to free it. Do not run water through it. If there is no blockage at all, then you will probably need to take it to a service center. But I am pretty confident that we are looking at a clog situation. Let me know if this fixesya! Thanks, Rene (vacuum Doctor)
Nov 14, 2009 | Miele S514 Solaris Electro Plus Vacuum
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Trouble with vacuum suction
Check and see if there is a blockage.
Jan 19, 2008 | Vacuums
Vacuums Logo
183 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
